2000 7.3 Excursion Problem
Old Jan 28, 2015 | 09:42 AM
Snocross705's Avatar
Snocross705
So I have a 2000 ford excursion and I'm trying to figure out if I need a new drive shaft or if it's something else in the back end. Every time I drive over 55 mph it starts vibrating real bad and when I go to turn, I can hear grinding in the back end. Anyone with an F250 or excursion who has had this same issue? Already changed U-Joints recently as well. Feedback would be much appreciated!
Old Jan 28, 2015 | 09:50 AM
AllaboutMPG's Avatar
AllaboutMPG
Have you had the rear cover off yet to make sure your not making metal? Picked the rear up and shake tires to see if anything obvious?
Old Jan 28, 2015 | 10:09 AM
Snocross705
I have, in fact we just put new wheels on about a month ago and it was fine.
Old Jan 28, 2015 | 12:16 PM
white Buffalo's Avatar
white Buffalo
How about taking the rear differential cover off? Inspect & change the fluid.....see if there is anything obvious. The last time I had a bad vibration at highway speeds, it was due to a tire being off balance when some of the weights fell off.
Old Jan 28, 2015 | 07:48 PM
whitetmw's Avatar
whitetmw
All good points. Did you change the universal joint and tires because it was doing this in hopes of correcting it. Or, did it occur following the work.
ExcursionQ13
May 24, 2016 09:22 PM
All Security
Jul 16, 2015 01:39 PM
377191
May 1, 2011 06:16 AM
GregGimbert
Aug 6, 2010 12:33 PM
