Slight "Pinging" Issue With My Engine
On the carb, I never had a huge problem with Autolite power valves, Holleys a little, I have never been a big fan of mechanical secondaries on automatic transmissions.
Nor am I fan a fan of mechanical secondary carbs in all but very specific applications. FWIW I got this dream carb setup I doubt I'll ever have the chance/need to build but think it would be AWEOME. A pair of Holley 4175s with all the tricks, secondary tuning, dual feed, center hung, weber emulsion tubes, etc. Installed back to back so the big bores are centered on a big tall dual plane manifold.
Or 4 IDA webers of course
, I love weber carbs(real ones) 5 jets and 2 changeable emulsion tubes per port they are a hugely fun challenge and work fantastic once you get them figured out. A clevor with 4 IDAs with a turbo blowing through them, awesome. I'm rambling, sorry.
Spark Plug Wire Sets & Accessories - Taylor Cable Products
As for heat, lots of products out there. I've find what taylor calls "Space Age Boot Protectors" rather practical, enough to do the job without being a big pain. Full Metal Jacket Aluminum Boot Shields - Taylor Cable Products
I'm a fan of what MSD just calls dual plug wire separators, As far as I can find MSD sells both 8ish mm size and a larger one, and taylor sells a version for there 10.4 wires. I find with 8 or so of these I can get the wires secured EXACTLY where I want them without the limitations of those bracket styles and much easier then clamp styles.
http://www.msdignition.com/Products/...eparators.aspx
T-Clip 409 & Clip-On Wire Separators - Taylor Cable Products
My plug wire install routine is both simple and complicated but I've had great success. First all V8 engines have basically the same firing order that has several aspects for looming. It starts with distributor timing placing. Done right two sets cross right next to each other at 6 and 12 o'clock, and 4 end up coming strait out, on Fords which depends on firing order. That way no wires cross over or have to go around the cap. Next plug all the wires in at the spark plugs, then loom up to the cap, then put on the end terminals at the cap.
I had to drop the primary jets down 6(!) sizes to correct the mixture to what you see on the plugs now. The "professional" who rebuilt the carburetor used size 50 jets in the primaries when that particular carburetor should have came with 42 jets. I settled on size 44 and that is what you see here.
Ever since I have corrected the over-rich condition, I have had to change the oil every few months to keep the oil brown instead of black. That is how I am "cleaning" the engine out.
So yes, there is a VERY real possibility that my engine still has some carbon build-up, but I didn't know that would cause pinging? It also does NOT blow black smoke out anymore when I get on the gas pedal; it only pings. I thought that, like spark plugs, the carbon would burn off once the problem was corrected?
Edit.
This is just kind of a curse of a carbureted engine, there are too many times when it's almost impossible to not be over rich. For example when cold, or whenever the accelerator pump is activated, all it can be is minimized to the point that it causes the least problems.
Back to being lean, idle needs to be adjusted in gear, vacuum is lower in gear thus it will flow less fuel in gear. But in gear load is higher and it needs more fuel, thus setting idle in park generally creates a lean condition. Also you make no mention of turning it back out a bit after finding that minimum fuel point.
Adjusting idle with auto...
1. Warm it up good.
2. Secure the truck, chock at the tires, parking break set, buddy behind wheel, etc. whatever you need to do to ensure the truck won't move while in gear and your in front of it.
3. Put in gear, doesn't matter which, I suggest reverse most of the time as it's safer for you in the front.
4. Go back and forth from side to side finding that minimum spot of least fuel with max RPM and vacuum.
5. Once there very gently open the throttle to see if it stumbles, likely it will a little. Turn both out 1/4 turn, try again, better? Another 1/4, even better? Continue until no improvement then go back in that last 1/4 that did no good, usually at about a 1/2 turn out from that minimum spot.
I don't think this is a cause of your ping, but there is a slight chance it contributes and no reason not to improve.
I am sure what he is talking about would be to run the engine about 2500 rpm then use a spray bottle like used to be used to dampen clothes for ironing before steam irons. Just fog a little into the top of the carburetor, it will cause maybe a slight roughness and one heck of a rattle as it loosens the carbon. You will see gray/white smoke from the exhaust as it comes out.
I would keep an eye on #8 plug though, if the problem reappears, then further investigation would be in order.
I'd suggest doing it before each oil change so any oil contaminated by the extra water leaves with oil that your changing anyway. Ohh and a HOT engine, as hot as possible, almost overheating, ideally you want all the engine parts over 212 deg, that's not possible in any practical since but you can get as close as possible.
I too like Webers, 48IDA for downdraft and 40DCOE for sidedraft (I have experience with both setups). Extremely tuneable carbs, I learned a lot from their "Technical Introduction to the Master Catalog".
I followed your link to Taylor's site, no custom Thundervolts for the 460, bummer. I still have a spark plug cable crimping tool (we used to keep bulk Packard 440 wire and an assortment of boots and ends) but it is for 7mm wire. That was a real useful item to have when you found a bad #7 wire on a big block Chrysler engine, they were 7 feet long on the 413, 426 wedge and 440! Maybe a universal set might work, right now it has a Motorcraft set on it.
I think the B-block, as in the 383, used the same set as the RB.
I cut and past the quote in brackets.
I never buy already terminated wires so applications rarely matter to me, I have a set of these to put the wires together, get it down it's pretty easy, they work great, cheap enough, do all I need, etc.
New Spark Plug and Primary Wire Strip Crimp Pliers | eBay
I replaced all 8 spark plugs (Motorcraft ASF-32, same as before) and wires (Ford Racing 9mm, replacing the Motorcraft 8mm) today and went for a test drive. To my surprise, the "pinging" problem seems to have completely gone away. I drove it about 30 miles today and opened it up HARD a few times, and there was absolutely NO "pinging" at all.
Man, this truck pulls harder than ever and absolutely SCREAMS now when I get on it and it winds up!
I hope this is a permanent fix and not something that comes back...
A few notes:
1. The Motorcraft plugs I was running before were gapped to 0.050", but I left them at the stock 0.044" this time. (Should I open them back up to 0.050?)
2. The Ford Racing wires were a bit thicker and fit MUCH tighter on the spark plugs and the distributor cap.
3. The Ford Racing ignition coil plug "snapped" on to the end of the coil; the Motorcraft plug wire did not.
Thank you ALL for your advice and ideas, and a special thanks to Gary Lewis, 85lebaront2 and BruteFord for responding to this thread by special request.
She bought these for me mainly because they were red, the same color as my truck, and she thought they looked "prettier" than the dingy gray Motorcraft ones I had. I just never bothered to put them on, because I thought the ones I had were fine. I know they are not really needed, but why buy a new set when I have such a great wife who thinks my truck is so FAST it needs a set of "racing" plug wires? Thanks, Babe!
Looks like I'd better get a set. Thanks. Hijack over.
