Replacement steering box recommendations
Old Jan 27, 2015 | 02:52 PM
Fandini's Avatar
Fandini
I've had a wandering problem with this 2006 ?F-350 since the day I drove it off the lot brand spanking new in 2006. Now we think that the valving in the steering box may be the issue since it tends to jerk back when applying constant pressure and holding in one spot. I see that there have been steering box issues when I've googled it. Can you guys recommend a quality replacement, Ford or aftermarket, that has been run and proven?
Thanks my FTEC brothers.
Old Jan 27, 2015 | 03:15 PM
Grant-Dieseltech's Avatar
Grant-Dieseltech
Red-Head Steering Gears - Custom Rebuilt Steering Gear Boxes in USA
I've had problems with every other brand, even Ford. Red head makes a great product with top notch customer service.
Old Jan 27, 2015 | 03:25 PM
Misky6.0's Avatar
Misky6.0
I love my Redhead steering box as well.
Old Jan 27, 2015 | 05:07 PM
CPB1's Avatar
CPB1
Post #375
https://www.ford-trucks.com/forums/8...talled-25.html
Old Jan 27, 2015 | 10:37 PM
Yahiko's Avatar
Yahiko
Before you take that jump. Check both the upper and lower ball joints.
You may find that you need them also. I find it better to know how deep
the pool is before jumping in with both feet.
Now that being said I would also go Redhead.
Sean
Old Jan 27, 2015 | 11:16 PM
Fandini's Avatar
Fandini
Sean
Anybody have bad luck with a Cardone steering box? I'm seeing that name pop up too as a quality and less expensive option.
Old Jan 27, 2015 | 11:46 PM
Yahiko's Avatar
Yahiko
I recall that something was said about it but what I can't recall.
You should be able to use the search tool to pull it up.
Sean
Old Jan 28, 2015 | 12:04 AM
04badford's Avatar
04badford
Have gone through the hole steering system, like Idler arm, tie rods. ?
Old Jan 28, 2015 | 01:04 PM
Fandini's Avatar
Fandini
This has been a problem since day one of a brand new truck. Been gone through by half a dozen shops as well as the dealer. Steering box has always had that jerk back on you trait. Mechanic at dealer said that was normal. Don't recall ever having that problem on any other truck or vehicle I've ever had. Finally ran across somebody at a heavy equipment shop that said that was NOT normal. It has gotten worse as milage has crept up. I'm looking for a quality replacement that will last. Don't want to deal with this again.
Old Jan 29, 2015 | 06:45 AM
DSMMH's Avatar
DSMMH
I had a wandering issue and adjusted the OEM box three times before I replaced it. It improved a little with each adjustment but still had to turn the wheel a lot to get the pig to turn. Replaced OEM box with Redhead box at about 60K miles and things got a lot better. Still adjusted it slightly once. Final solution was to replace the steering from the control arm to the ball joints at 122K miles. I also replaced the OEM hubs while I was there with Timkin hubs. Total for labor, MOOG steering parts and ball joints, misc. seals, alignment and hubs (included auto hub rebuild) was about $1800. Drives like a new vehicle with a rack & pinion steering gear.
Ed
Old Jan 29, 2015 | 11:14 AM
Fandini's Avatar
Fandini
Does anybody have any positive feedback on Motorcraft replacement or reman steering boxes? I've often found that OEM parts are clearly superior to aftermarket replacements.
Old Jan 29, 2015 | 11:21 AM
Grant-Dieseltech
I've had problems with OEM and A1.
Old Jan 29, 2015 | 11:36 AM
Fandini's Avatar
Fandini
Is A1 a Cardone unit? I guess you've had the opportunity to wrench on quite a few and see quite a bit of stuff being a diesel tech right?
Old Jan 29, 2015 | 11:51 AM
Grant-Dieseltech
Yes A1 is cardone.
The main thing I see with the remans is that they like to replace seals and bushings, paint it and call it good. They ignore wear on the gear its self and reuse parts that shouldn't be. The last Ford unit I got had almost 1/4 a turn of play. I've had A1 units that leaked do to shaft burrs, were too loose and even one that felt notchy. It had a chipped tooth and they still put it back together and sold it.
Redhead is the only company that I have yet to get one that's bad in the box from. Doesn't mean it never happens, nobody is perfect.
The first one of theirs I got is 5 years old. Its nice and tight still but the seal is starting to seep. The box has more miles than the factory box did at the point it was too loose to be safe. Now on the other hand, customers don't always want to spend the money so I still install other boxes.
The last AC Delco box was a touch loose but expectable. The last A1 box I used felt great and worked great so maybe they have fixed some quality problems since I stated hating them. The chipped tooth box was only a year ago though.
Old Jan 29, 2015 | 12:42 PM
Fandini's Avatar
Fandini
Yes A1 is cardone.
Great info! Cardone units aren't cheap either! At least not the ones with the upgraded shaft and gear components. Seen them priced from 300 to 600 bucks. Have you had the chance to use the ones with the upgraded gear and oversized shaft components?
