HID Lights
Old Jan 29, 2015 | 07:17 AM
JR2's Avatar
JR2
Originally Posted by Stewart_H
Do you have a recommendation for someone who already has the HID kit but needs a projector housing?
Regardless of where you purchase the projector housing, you will have to cut up, modify, and re-seal your existing headlight.
Write up that has pictures of work needed:
https://www.ford-trucks.com/forums/5...-retrofit.html
Old Jan 29, 2015 | 11:03 AM
AlaskanEx's Avatar
AlaskanEx
Bleed Ford Blue
Please don't lump LED plug and play kits with HIDs as far as output/cutoff. As my photo above clearly shows my HIDs have a cutoff just the same as my headlights with a stock halogen bulb.
I also tried LEDs in one truck to try it, just like you had happen it was a huge blob of light. NOTHING like HIDs in the same housing.
Old Jan 29, 2015 | 11:42 AM
ATV PRO #11's Avatar
ATV PRO #11
I'll second this.
LEDs tried by a couple friends. Negative feedback along with my own.
Old Jan 30, 2015 | 12:01 AM
Watcher58's Avatar
Watcher58
VVME is the company I use and have since 2007 with one kit being a '07 with no bulbs/ballests replaced. I run them in all my trucks, aimed correctly and have never been flashed. I use a hi/low kit so i have full low beams and high beams.
I'm not a fan of projectors and the extreme sharp cutoff, really sucks with all our hills.
low beams
don't have the bronco anymore
Hmm I did not know that about the sharp lines of the light pattern. I live in MT so there are long long rippling plains where you are looking for deer, elk, cows, horses, or someone just plain stupid to run in front of you. I guess VVME is something I should really look at.
Old Jan 30, 2015 | 12:48 AM
Irish19614x4's Avatar
Irish19614x4
JR2,
Love the X, by the way what size is that LED bar in your bumper as a replacement instead of fog lamps. Looks nice and love the rims and stance! What size tires? Suppose I can just go measure my opening and order my LED bar
Old Jan 30, 2015 | 12:50 AM
Irish19614x4
Today I just ordered HID lamps for my X and I run a set on my F350 Dually now for almost 8 months no problems. I run the 6000k light, which works great for what I need it for. Since the supplier is local to me in SOCAL I just go with them, like I said for $35 a set and have lasted 8 months this far I have no complaints.
Old Jan 30, 2015 | 06:40 AM
BEARDOWN's Avatar
BEARDOWN
Originally Posted by JR2
My first post on FT, but, not my first car forum post....
A little background on my ride:
2000 7.3 PSD Excursion
X & modded B's - "level"
2005 Full OEM front Conversion
2006 OEM HD Black Headlights that use "H13" bulbs.
I agree this light bar looks great. What one are you using? And how did you mount it up?
Old Jan 30, 2015 | 01:54 PM
Stewart_H's Avatar
Stewart_H
Originally Posted by Irish19614x4
...what size is that LED bar in your bumper as a replacement instead of fog lamps.
I dunno what JR used, but a 20" Rigid light bar fits there.
As for mounts, I'd be interested to know if he used a KD Fabworks mount or not.
Bumper Brackets for 20" LED light bar - 99.5-04 Ford Superduty F250 F350
Bumper Brackets for 20" LED light bar - 05-07 Ford Superduty F250 F350
Stewart
Old Jan 31, 2015 | 11:48 AM
JR2's Avatar
JR2
JR2,
Thank you!
LED bar is the CSI Dual Row spot beam with the KD Fabworks brackets as mentioned by Stewart. (don't waste your $$ on the rigid)
Bumper Brackets for 20" LED light bars - 05-07 Ford Superduty F250 F350
The KD brackets are worth every penny. Not worth fabricating yourself unless you have a bunch of time and no $$
Since my truck is a 2000 and does not have wiring for fog lights, I used this wiring harness, mounted relay next to fuse box and ran the wire down to the bumper:
HARNH1 HARNH1
(I wired in the harness to my high beam circuit and It's a great driving light)
Tire and wheels:
305/55r20 Wrangler Duratrac
Method Racing "Standard" 20x10 with 4.5" backspace / -24mm offset wheels
(rear fender liner rub when turning @ some angles)
Old Jan 31, 2015 | 06:31 PM
xhid's Avatar
xhid
Stewart
Yes. hidplanet.com is owned byThe Retrofit Source Inc. Tons of info of how to do it right. Yes its more difficult than throwing a kit in a stock housing but the results are ten fold better. TRS is a great company to deal with and they know there S***
Tyler11T
Appearance & Dress-Up
Jun 8, 2018 11:29 AM
GreeVan
Feb 9, 2017 07:54 PM
NorEasterMA
Oct 3, 2014 02:57 PM
jaye
Jan 21, 2011 04:33 PM
Still Smoking
2004 - 2008 F150
16
Nov 9, 2010 04:05 PM
