Just purchased mine for my 7.3l excursion, only concern i have is that the previous owner had a tuner on the vehicle and never put the factory setting back on before he traded it in. the tune on here is just a basic one for Millage. what should i do before installing my TS chip or will the TS chip just delete the one thats currently on it?
what i was hoping to hear, just looking for a few others to respond about it not saying i wont trust your answer but more that say the same safer i feel
If you want to re-flash your PCM to the stock calibration, you'll need a J2534-1 and -2 compliant device and software Or, the device which altered its programming.
Which tunes/programs did you decide to go with? The reason I ask is that you do not want to push it in some of the higher HP programs without having a EGT gauge (pyrometer) to monitor.
Haha thanks I have a buddy with a 7.3 f250 so I've been questioning him a lot with this stuff and he suggested the chip and said he loves it so tomorrow once it arrives I'll be installing it 👍👍
Thanks for posting this. I'm actually shopping for a chip now. I'm trying to decide between TS and DP. I like that TS comes preloaded, but I have not seen a tune specifically for towing. What pushed you to TS?
Welcome to the forums. You may want to look at Gearhead (gives you access to a huge library) and others as well.........as you mod your truck you will need updated tunes to support those mods. Some have free lifetime updates and some don't....you could wind up spending hundreds more in the long run.
Total Diesel Performance sells TS style chips with what ever tunes you want. To save money, you don't need to put 6 tunes on it. I only had 4 burned on mine.
