Air Fuel Ratio Issue
2000 4x4 Excursion V10 2V
So I have tuned a couple vehicles and one of the things that is standard on all the pcms I have done is when you let off the gas pedal while going down hill the AF ratio leans out to 22:1 or so.
Basically the pcm cuts fuel while coasting with negative load.
I am seeing this ocasionally on my V10, basically after a hard pull and I let off go pedal the AF ratio will lean out to about 22:1.
Problem is if I'm just crusing down the hwy at 65 or 75 mph and let off the pedal the AF ratio stays at 14.7:1 or so.
This affects fuel mileage and I don't think it's right. What can be done to fix this?
I believe the stock V10 is programmed to maintain stoichiometric (14.7 / 1) air fuel ratio at all times when in closed loop. That is why the tuners can give a little more power at WOT by going down to around 12.5 / 1 and letting it run open loop.
A good question for 5 Star would be if it can go open loop on coast also.
underthebridgejim
11-18-2016 12:08 AM
morrigj83
01-30-2011 02:30 PM
jav409
03-19-2006 04:06 PM
JoeDiesel61
02-26-2002 02:51 PM
