Air Fuel Ratio Issue - Ford Truck Enthusiasts Forums
Modular V10 (6.8l)
Old 11-08-2018, 10:04 AM
rock2610d's Avatar
rock2610d
rock2610d is offline
rock2610d is a name known to allrock2610d is a name known to allrock2610d is a name known to allrock2610d is a name known to allrock2610d is a name known to allrock2610d is a name known to all
2000 4x4 Excursion V10 2V
So I have tuned a couple vehicles and one of the things that is standard on all the pcms I have done is when you let off the gas pedal while going down hill the AF ratio leans out to 22:1 or so.
Basically the pcm cuts fuel while coasting with negative load.
I am seeing this ocasionally on my V10, basically after a hard pull and I let off go pedal the AF ratio will lean out to about 22:1.
Problem is if I'm just crusing down the hwy at 65 or 75 mph and let off the pedal the AF ratio stays at 14.7:1 or so.
This affects fuel mileage and I don't think it's right. What can be done to fix this?
Old 11-08-2018, 06:31 PM
super 6.8
super 6.8 is offline
super 6.8 has a good reputation on FTE.super 6.8 has a good reputation on FTE.super 6.8 has a good reputation on FTE.
I believe the stock V10 is programmed to maintain stoichiometric (14.7 / 1) air fuel ratio at all times when in closed loop. That is why the tuners can give a little more power at WOT by going down to around 12.5 / 1 and letting it run open loop.
A good question for 5 Star would be if it can go open loop on coast also.
Old 11-08-2018, 10:35 PM
rock2610d's Avatar
rock2610d
I know all that but when coasting with negative load it should shut off fuel like most all efi vehicles.
AF ratio should lean out to 22:1, mine only does this occasionally.
Contact Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
© 2018 MH Sub I, LLC dba Internet Brands
