New 400 Running
Old Jan 25, 2015 | 10:21 PM
Raleigh1's Avatar
Raleigh1
New 400 Running
Been reading a ton in this forum and it has been a great help.
Did the cam break in on my newly built 400 today this one tight engine! The oil pressure is amazing and I love the way it just stops when it shuts down. Hopefully going to exhaust next weekend!!!
I also have a video of the break in, damn I relieved everything went well.
1978 Ford Bronco 1978 Bronco video | SuperMotors.net
Thought I would share another "boat anchor"
Old Jan 26, 2015 | 06:45 AM
Gary Lewis's Avatar
Gary Lewis
Cool! What components do you have in it?
Old Jan 26, 2015 | 01:41 PM
Bud Mud's Avatar
Bud Mud
yea what Gary said, tell a bit more about it. Pic's are always a good thing also.
Old Jan 26, 2015 | 04:30 PM
Raleigh1's Avatar
Raleigh1
So it is a 400 bored .040 over and deck shaved .020
All Cleavite Bearings
KB Silvolite pistons (stock replacements)
Comp Cams 32-242-4, 262/.513 Intake, 275/.519 Exhaust
Lunati Dual Valve Springs
Comp Cams double roller timing set
Edelbrock Performer 400 intake
Holley 2D Pro-jection TBI
Doug's Shorty Headers
I went with stock pistons because I plan to install a remote turbo set up after full break in is complete (about 2500 miles) so I actually wanted the compression to be a bit low.
Old Jan 26, 2015 | 04:48 PM
Gary Lewis's Avatar
Gary Lewis
Sounds very good! What do you think of the headers? I'm trying to figure out what I want to run.
Old Jan 26, 2015 | 07:27 PM
Raleigh1's Avatar
Raleigh1
The headers are great and the quality is top shelf. Solid 3/8" machined flanges, thick walled tubing, ceramic coated, love them.
I had to "massage" the heat shield to make the passenger side collector flange clear.
Old Jan 26, 2015 | 07:29 PM
Gary Lewis's Avatar
Gary Lewis
Thanks. That looks like a good possibility. A mid-point between stock exhaust manifolds and full-length headers that hang way down.
Old Jan 26, 2015 | 07:46 PM
Raleigh1's Avatar
Raleigh1
How about some build pics:
Bearings from the "newly built" engine that came in one of the 3 Broncos I bought for this build, looks like someone didn't know how to prime an engine.
Block back from the machine shop, bored .040 and shaved the deck .020
Heads with new new valve guides and hardened seats with 3 angle valve job.
Ports were smoothed and slightly ported, nothing crazy.
Valve Springs, stock vs. Lunati 248# springs, lol
Double checking clearances and rod/cap locations
Setting the new pistons in place, TIGHT!!!
Comp Cam, another quality piece
Take off of one and put on the other haha
Engine set in place.
3G alternator, a must have upgrade!
Pretty much ready to start, still need to install the core and radiator
Core Support and radiator in place
And that is most of the engine pics, I have some others but these are the best quality.
Old Jan 26, 2015 | 07:52 PM
Raleigh1's Avatar
Raleigh1
Huge upgrade over stock, and as far as long tubes, those are extremely difficult to fit on a Bronco. Usually the exhaust has some extreme angles that are no good for full flow.
Old Jan 26, 2015 | 08:43 PM
Gary Lewis's Avatar
Gary Lewis
Pics look good. And, I agree on the need for the 3G. But, what's that automagic belt tensioner doing on a '79?????
Old Jan 26, 2015 | 11:53 PM
SDDL-UP's Avatar
SDDL-UP
For whatever it's worth I also had to "massage" the heat shield to get my Hooker Competition headers to fit the passenger's side. Could be that's a typical tight spot.
What's up with that second bearing? Ouch! First one doesn't look good, but that second one - something went seriously wrong there!
Great looking engine!
Old Jan 27, 2015 | 12:23 AM
Raleigh1's Avatar
Raleigh1
Part of the Nostalgic A/C kit, the Bronco didn't have A.C. and that was not going to work here in Vegas lol
Old Jan 27, 2015 | 12:25 AM
Raleigh1's Avatar
Raleigh1
Not sure, the only thing I can think of is a dry start or it too long to get oil back there, it was on #7 piston. Either way that is not a problem for the new motor!
Old Jan 27, 2015 | 08:03 AM
Gary Lewis's Avatar
Gary Lewis
Raleigh - I assume yours are Doug Thorley headers?
Old Jan 27, 2015 | 04:48 PM
Raleigh1's Avatar
Raleigh1
They are these headers:
Doug's Headers Online Store
