Thinking about a used Explorer
Old Jan 25, 2015 | 07:59 PM
89F250_7.5's Avatar
89F250_7.5
Hi,
My '02 Escape with 235,000 miles finally gave up the ghost. The trans died and every quote I got was for far more than the car was worth. I drove it off the lot at 3 miles, so it was a good car for us.
I'm now considering an early to mid 2000's Explorer. Also considering xTerra and a few others.
Are there particular years or engine/trans combo's I should avoid? I already have a 2003 BMW, so I'm not looking for another DIY car. I don't mind small stuff and PM, but I don't really feel like doing full tear downs.
Anyway, that Escape was so good to me, and I've been a lifelong Ford guy, I'd really like an Explorer if I'm not setting myself up for hassles.
Thanks for your input
- Brad
Old Jan 25, 2015 | 08:39 PM
85e150's Avatar
85e150
Older OHV V6 models have few engine troubles.
SOHC motors are trouble 'til about '03, then they are slightly less trouble.
Transmissions in early models (4 speeds) behind the OHV V6 were "ok". 4R70W's behind V8s were good. 5 speed automatics are trouble and frequent maintenance. Rear axle bearings were sourced from some 4th world backyard foundry with slave child labor. Expect a howler, almost any year. You might or might not get one.
Some of these run out past 200k with none of the above. Some don't.
Buy the newest V8 with good maintenance records. If a trans or rear axle has been repaired, all the better. Repairs many times result in a better part or installation, or in the case of the transmissions, an extra filter if done by Ford. Plan on trans fluid drain/refill every 30k.
I bought a '99 stripper for the kids after our '98 XLT got whacked. I could kick myself as there are many V8 Eddie Baur, XLT etc out there. Don't get in a hurry.
Old Jan 25, 2015 | 09:26 PM
ashleyroachclip's Avatar
ashleyroachclip
I have had a first gen and second gen with 0 problems.
The first gen was a 91 , had no trouble with the transmission, it had been serviced regularly, they have the 4.0 engine, and it is solid as a rock.
Second was a 95, also no trouble.
The 8.8 is as reliable and built proof as they come.
Service the transmission, and it is also very dependable.
I never ran firestorm tires, and had no handling issues.
There is no reason to be concerned with an explorer, tho I would not buy a 5.0.
Those are full time all wheel drive, poor mileage.
Old Jan 25, 2015 | 11:27 PM
khadma's Avatar
khadma
Carpenter Local 745
My wifeʻs 07 is great and no transmission issues and no engine issues. We bought the truck used with 10,000 miles on it
back in 08. It is a 4x4 4.0 getting around 17 MPG.
It now has only 74,000 miles on it. One thing about this gen Explorer that is good to have is the part time transfercase.
Old Jan 26, 2015 | 08:07 AM
05MilMachine's Avatar
05MilMachine
Our old 04 Explorer that my in laws now drive was purchased new with no miles and now has over 220K on it. Still going strong however it has had a few rear end rebuilds and a bunch of front hubs (ONLY use Motorcraft/Timken hubs for minimum trouble) and a few rear bearings, but overall, trouble free. Our 2010 Mountaineer also purchased new, has been great and now has 106K on the clock. I just went through the front bearings and brakes and the rear bearings are just now starting to let me know they are back there. Trans has been flushed at 50K and its due now. I recommend a 2007 to 2010. Enough revisions to be less trouble. I would say 2006, but those are weird when it comes to parts, like a transition year or something.
Old Jan 26, 2015 | 08:07 PM
89F250_7.5's Avatar
89F250_7.5
thanks for the feedback guys
HOOTs95PSD
18
Apr 3, 2017 06:26 AM
Rico47635
16
Feb 7, 2011 11:12 AM
1984 f-250
Ford vs The Competition
May 5, 2004 06:15 PM
knucklehead11
20
Sep 5, 2003 12:15 AM
Dwarwick
May 23, 2002 06:07 PM
