TPS keeps going Bad?
Old Jan 25, 2015 | 02:07 PM
mousty's Avatar
mousty
I have a 94 F150 with a 5.0 4wd extended cab? Can anyone tell me why the tps sensor keeps going bad? I have put 3 in in a year so far? Only codes are EGR valve and excessive torque converter slip. Tranny does slam intermittently? Any help greatly appreciated!!!! Thanks in advance!!
Old Jan 25, 2015 | 02:38 PM
timbersteel's Avatar
timbersteel
What brand of TPS? What leads you to change it?
Old Jan 25, 2015 | 02:41 PM
mousty's Avatar
mousty
I put one in from Oreiley's and one from NAPA, Service center tested and said bad an replaced? Brand I don"t know.
Old Jan 25, 2015 | 03:06 PM
timbersteel
I would be inclined to test the TPS. I would ohm it out first. Then check voltage for closed and then watch for voltage spikes or dips from closed/stopped voltage to full WOT.
And because the TPS is so very important to electronic transmission, I only use OEM, Motorcraft. Same would hold true for Dodge, GM and so forth. Its usually not worth my time to justify a few dollars saved if I cant rule out that being part of the problem.
Old Jan 25, 2015 | 03:13 PM
mousty's Avatar
mousty
I am going to take to shop this week. Have test tps and replace mlps. Son said killing when put in reverse now! Thanks for help!
Old Jan 25, 2015 | 03:35 PM
rla2005's Avatar
rla2005
Aftermarket TPS sensors tend to have very poor quality control. But before throwing in the towel it would be advisable to check it yourself with a meter.
Old Jan 25, 2015 | 06:26 PM
FordxFour's Avatar
FordxFour
There is a good reason that the Motorcraft one costs 4 times as much. You do get what you pay for.
Old Jan 25, 2015 | 07:13 PM
NotEnoughTrucks2014's Avatar
NotEnoughTrucks2014
Sounds like time for a TPS how to.
Part 1 -How to Test: Throttle Position Sensor (1988-1995 Ford 4.9L)
Old Jan 25, 2015 | 07:59 PM
subford's Avatar
subford
Excessive torque converter slip will cause the Tranny to slam.
Elisvk
Jun 17, 2014 09:19 AM
captain2207
Mar 20, 2013 09:15 AM
cdknechtel
1997 - 2003 F150
Apr 18, 2009 02:13 PM
gaffmedic
Mar 21, 2005 02:08 PM
ewellman
Aug 25, 2004 01:59 AM
