390 Blown up
Old Jul 21, 2003 | 07:28 PM
Andysutt's Avatar
Andysutt
390 Blown up
I jsut fired my motor and broke it in....
I had the electric fan running, and I left the radiator drain cracked a bit, and a water hose constantly pumping water in the radiator (fresh cool water to keep heat down)
Well... it broke in fine, ran fine and everything...
BUT.... On the passenger side back of block it leaks a ibt of water.
What could it be. Its leaking like up by the head. I hope its not a head gasket.
But I wanted to check here before I tear it apart.
Old Jul 22, 2003 | 05:57 AM
76supercab2's Avatar
76supercab2
390 Blown up
Could it be a freeze plug? I'd get back there with a flashlight and a mirror and try to see it leaking.
Old Jul 22, 2003 | 02:06 PM
Andysutt's Avatar
Andysutt
390 Blown up
I'll check that out... Freeze plug in the heads?
I forgot if it had them honestly. lol
Old Jul 22, 2003 | 06:10 PM
FE427TP's Avatar
FE427TP
390 Blown up
did you use a performer RPM intake or your regular one? could it be a intake gasket leak
Old Jul 22, 2003 | 08:02 PM
Andysutt's Avatar
Andysutt
390 Blown up
I used stock 4 barrel intake..
If its the intake gasket leaking Id be VERY surprised.
As its got the gaskets and a TON Of silicone...
I made sure it wouldn't leak.
I'll have to take it off to fix the head gasket (if thats the problem)
so I'll redo it also.
