I have start up problems??????
Old Jan 24, 2015 | 02:26 PM
Tony twigs's Avatar
Tony twigs
I have a 300 six 96 model it starts great in really cold weather and fist thing in the morning. Drive it for about ten miles shut it off re start it will try to start but sputters and dies wn it finally starts smells flooded. Have changes temp. Sensor
Old Jan 24, 2015 | 02:34 PM
rla2005's Avatar
rla2005
Why did you blindly change a sensor without checking for codes?
Old Jan 28, 2015 | 03:03 PM
Tony twigs's Avatar
Tony twigs
It's not reading codes and it had some frayed wires and had advice from another person from this site to start there. I'v had it in the shop a few times. Still no luck.
Old Jan 28, 2015 | 03:12 PM
David7.3's Avatar
David7.3
Check your fuel pressure regulator for leaks, pull the line off and see is you can see or smell fuel, you really need to scan for codes, and check live data. If not your just throwing parts at it without diagnosing it properly. Sounds like spark, spray water around the coil and wires and have someone crank it over as your looking at the coil and wires, you will see and hear arcing, may not be getting enough spark when she is warm, carbon tracking is worse when it's warm.
Old Jan 28, 2015 | 03:22 PM
rla2005's Avatar
rla2005
In many cases there can be a stored code without a Check Engine Light so it's best practice to check. In light of the updated info," it had some frayed wires", I guess it would be prudent to head off other issues.
Which Temperature sensor did you change..there are two? (Assuming you are referring to the Engine Coolant Temperature ECT) One for the temperature gauge, the other for the computer.
For reference from Subford:
mattmattf14
Jun 11, 2017 07:19 PM
macd89f250
Jul 24, 2012 11:12 AM
smbutton91
Dec 6, 2010 11:03 AM
elee3
Oct 27, 2009 09:21 PM
Talyn
Jan 12, 2005 07:55 PM
