Sponsored by: Real Truck
tranny squealing when shifting gears
Old Jul 21, 2003 | 05:38 PM
iflooru's Avatar
iflooru
I'm only a couple months away from my warranty expiring and am getting concerned about some tranny noises. In most cases the noise occurs while trailering my boat or if I have a large load in the cargo area. The automatic transmission is squeaking during the gear changes. Only squeaks for about a second. It will rarely do this without a load unless I'm in passing gear and over 5000rpms. My concern is that when I take it into the dealer's service dept I'll likely get a "road test vehicle, could not duplicate" on the work order. Can anyone help me as to what's occuring so it seems like I know what I'm talking about in front of the service manager? Does a filter and fluid flush solve my problem or should more be done? I have a V10 Excursion with 4.10 gearing if that makes any differece. TIA
Geo
Old Jul 21, 2003 | 06:57 PM
99f350sd's Avatar
99f350sd
Well at the minimum get it documented at the dealer. Have you checked the fluid level..? Take it to a good tranny shop and ask em what the noise is they could probably tell you or have an idea..
Old Jul 21, 2003 | 07:25 PM
NoMo's Avatar
NoMo
Are you sure it's the transmission and not the serpentine belt? I've heard of some belt slippage right after a shift that many thought was a transmission noise. A new belt &/or idler pulley eliminated the noise.
Regardless, you should definitely take the truck in and have the problem documented... just in case it is something bad.
Old Jul 21, 2003 | 08:04 PM
iflooru's Avatar
iflooru
I'm sure it's not the serpentine belt, however the sound is similar, yet more subdued and muffled. It's the transmission screeching during hard shifts. I believe there are belts inside the transmission and perhaps that's what is making the noise. It happens during the shift up to the next gear. Fluid level is OK.
