Does anyone know of a good in cab fuel pressure gauge?
Is there a stand alone egt gauge?
I have the SG2 but truck is not equipped to read fuel pressure.
I went with the Edge Insight EGT add-on. I considered it for the fuel pressure but it is a bit spendy. Then I looked at the ford match fuel pressure from autometer which would match my boost gauge above the rear view mirror and that was also spendy. So then I did nothing.
X2 what Iaff said, I like the Edge Insight line with the EAS starter kit as additional pressure sensors, temp sensors and or back-up camera can be added without cutting into the factory wiring harness and the install is clean looking. The only down side is the expense.
The only problem with the Edge system is you are limited to the number of PID's you can monitor. I tried setting up the different screens with different PID's and got a warning. Edge CS confirmed that there is a limit. No deal breaker, but I found nothing mentioned in the install manual.
The audible alerts are great and I use the EGT probe with the Edge.
I have the entire edge set up. Just easier for me being plug and play pretty much.
I was wandering about that--the cts you can add backup camera.
Just looked at a price (was probably just the standard and no EAS kit) but it wan't too bad--about the same as buying two gauges and the goodies to install.
I like the part about not cutting into the wiring harness.
yall make it hard on a man to make a decision lol.
You can have an alarm for a pid that isn't displayed and it will pop up that one.
I installed a single A-pillar digital gauge which displays 2 values. In my case I got fuel pressure and volts (I didn't think I needed EGT at that time).
I was able to retain the grab handle which is what I really wanted...
