two gauges in one - install on the A-pillar
Finally got home early from work - and it wasn't raining
so I could finish up the wiring under the dash.I "needed" to add a fuel pressure gauge, and decided to put it on
my A-pillar,but I also wanted to monitor voltage so I could free up 1 reading on my Scangauge2. I was considering the Ford Racing
fuel pressure gauge from Autometer ($220) and then just use
a "cheap" digital voltage display stuck to the dash. But, I didn't like
the cheap look and decided to get the dual-gauge.
It's a standard size 2 & 1/16" digital gauge that displays input from 2 different sensors. You can select from a variety of
combinations of sensors - I needed fuel pressure and voltage, but
others could use fuel pressure & EGT in a single gauge and retain
their grab handle - here is the link on these gauges.
Dual Gauges
The gauge comes with the sending unit(s) a pre-fab cable wired for
the 2 sensors you choose in a nice 12-pin snap-on connector.
I ordered the 6.0 fuel pressure adaptor hose kit from Strictly diesel
along with the autometer 15318 Single Gauge Pod, and the
Medium Pebble matched paint.
The Autometer pod required a little mod'n to get it to fit.
Not sure if it's because the Excursion pillar is different than the
super duty or not. It only took 5-10 minutes with a dremel tool
to carefully remove the material in the places that didn't allow it
to "snap-in" around the pillar - it is pinned in real tight..
The gauge snapped right in to the pod after just a tiny bit of filing to one edge
of the pod. The gauge is just pressed in.
The sensor is pre-wired to a 4-conductor "cable" which was a bit
tricky to feed through the firewall. I decided to pull out the grommet/bushing around the wire bundle and put a small slit into the
outer ridge and push the connector through. Once through the
rubber grommet/bushing fits tightly around the cable and easily pushed
back into the firewall - and it's sealed nice and tight.
I have yet to install the fuel pressure sensor and adopter, along with
the blue spring upgrade kit - hopefully this weekend.
And I will put plumbers tape on the sensor threads.
The paint is a very close match - I gave it 3 light coats and I'm real
pleased with it. I have to find a home for the "button" which
allows me to configure the gauge's refresh rate, brightness, etc.
In the picture with the gauge "on", the truck is not running.
So the fuel pressure alarm light is on and so is the low voltage light,
I have it programmed to alarm at 12.4 volts.
I'll update once I complete the install.
When I painted mine...I used a Krylon camo paint that didn't match that bad actually...I think it was $4 at the time and is good for plastics...I was having a hard time finding the Ford medium parchment locally and was too cheap to spend $25 on a can of spray paint shipped to my house
You will really like having the gauges right there!
Looks great guys! Some day I will get around to getting a couple gauges in my X. I realized I should have at least a trans temp gauge in my X after pulling some long grades in WV a little over a week ago. My stock engine coolant gauge was moving around like a gauge should but the trans temp "LOL" gauge was useless. Thats another thing that ford pisses me off about, why have gauges if they aren't gauges?
The factory gauge will actually move once the trans temp tops 220°
take a look at this picture
What I've done is mark my instrument cluster clear cover with a white grease pencil for the spot the trans temp NORMALLY sits...in the attached photo...that would be from 100-220°.
Notice the white mark in this photo...I've marked my oil pressure, engine temp and trans temp in this manner...this way when I glance down at the instrument cluster...if the needle is BEHIND the white mark...I know everything is NORMAL!
I wish it would stop raining here so I could install my blue spring kit & FP sensor.
It is a shame the stock "gauges" are what they are. Too bad we can't
just cut a 2 1/16" hole where each stock gauge is and put in a real one.
I rented a Chevy Traverse a couple weeks ago and their gauges had
voltage markings on their gauge and it appeared
to be accurate (engine off, key on - lights on voltage 11-12.
Started the car voltage 14) I would guess temps also were true gauges.
Strange how Ford feels drivers of "trucks" would be content with
gauges that don't move even when under load/uphill until - "boom".
Every chevy I've ever owned had real gauges. Still love my first Ford a LOT better!
They feel the trans is SAFE up to 220* so the gauge is solid up to that point...
I can only imagine some folks calling the dealer day in and day out because their gauge moved a little...
But I would have like to see movement about 210* so you know you are heating up and can start to take some precautions BEFORE it is already at 220*...
Typically "moving" gauges for the lay folk causes concern...that's my take/assumption as to why they did it this way...
But I am WITH YOU that I would have liked to see an earlier movement of the trans gauge...my solution...add a gauge to give me what i want since I tow heavy under some tough terrain and weather conditions...
EGR valve (dang it was crusted, had a tough time cleaning out the
internal passages they were gunked up so much).
Took it for a test drive - nice!
But they are "trucks", people driving a truck should understand stuff like this. I know lots don't but they would learn. Chevy gauges move around all the time and no one complains.
