Vibration Diagnosis...
Old Jan 23, 2015 | 11:23 AM
carbon coupe's Avatar
carbon coupe
I had the same issue recently. Replaced u-joints/balanced and its smooth as glass now. Only cost me $120 and they painted it too!! My slip joint was/is good, just needed grease.
Old Jan 23, 2015 | 11:26 AM
exbxtoy's Avatar
exbxtoy
Originally Posted by Splash67
Interesting...not to sound crazy but could you post a picture of your rig with the lift and stock tires? There's a good chance that I'll end up having to run on stock rubber for a while, even after Monster gets a 4"-6" lift. I'm curious how it might look.
Sure, I will post a few pictures when I can figure out how to do so. Is it possible to post via the mobile browser, I am on my mobile phone most of the time and do not see a way to post pics from my phone.
Old Jan 23, 2015 | 08:10 PM
The2003Excursion's Avatar
The2003Excursion
Newer ujoint don't mean much if they munched them on install last time. The one I replaced was an aftermarket one. The front was original and in good shape. Not messing with it until the 50° mark comes around if it will hold out.
I thought it was the cop and a front wheel bearing at first. Finally got bad enough it was obvious it was in the center of the vehicle, not out board, and it was getting louder.
Old Jan 24, 2015 | 01:13 PM
sessland's Avatar
sessland
Update:
2. As suspected the "Tow/Haul" mode did not make any difference.
This would only have made a difference with a v10. I didn't catch you were a diesel guy.
Old Jan 25, 2015 | 11:58 AM
Splash67's Avatar
Splash67
Yeah I know, no problem. Hitting a button while I was cruising down the highway was pretty easy...and cheap! 😉
Sent from my Samsung Galaxy S5 using IB AutoGroup
Old Jan 27, 2015 | 10:25 PM
Splash67's Avatar
Splash67
I'm pretty sure that I have it narrowed down to a bad U-Joint.
This part of the bearing is obviously coming apart.
You can see what appears to be grease seeping out of the bearing.
If you look closely you can see metal shavings coming from this part of the bearing...metal savings coming from a bearing are never a good sign.
Old Feb 3, 2015 | 08:47 PM
ghglenn's Avatar
ghglenn
Nailed it.
Old Feb 10, 2015 | 11:00 AM
Splash67's Avatar
Splash67
Originally Posted by ghglenn
Nailed it.
Yup...now I just need some $$ and time to replace it. Well a little warmer weather for this driveway DIY mechanic would be nice too! I hate laying in the snow to work on the underside of Monster....BBRRRRRRRR!!
Dave042
2009 - 2014 F150
38
Jun 25, 2024 10:35 AM
khendrix
2004 - 2008 F150
Nov 2, 2004 06:59 PM
ultramax21
2004 - 2008 F150
Jul 27, 2004 10:35 PM
