I'm looking for a 12-14 inch off the shelf suspension lift for my 1978 ford f-150 4x4 but all i can find is 9 and i have a flatbed so body lift isn't an option ideas or suggestions would be greatly appreciated!
To find that much lift just in suspension "off the shelf" for a 78 1/2 ton, I doubt its out there, especially for a 1/2 ton.
It will probably have to be custom built $$. Things like radius arm drop plates, big coils springs, all new rear springs arched like crazy to stay away from a stupid tall axle block.
Steering is going to be a nightmare, cross over conversion time yes? All that and does the truck still have a D44 front and 9" rear axle?
Probably still have a married NP 205 transfer case? Will need to go to a divorced xfer case and lower it unless you want crazy d/s angles? Hope it is not a short bed either.....
Get the 9", 3" body lift the cab, and the flat bed....if you just have to go that big? 44", 46", 54" tires, needs a big motor, tough trans, D60's front and rear, chrome moly axles, CTM u joints......
You're stoned and probably don't even have a welder.
moneypit....you are right about that. lol
Wouldn't the cab be lifted higher then the flatbed if I only done the body lift on the flatbed? And I was only curious about it I have a newer truck also and they make 14 inch lifts that just bolt on.
Put the 3" body (cab lift) on and then make the flat bed lift spacers to make the flat bed the appropriate height.
14" really...well it's NOT a new truck, so I bet absolutely NO off the shelf lifts that much either.
You might as well go buy a surplus 5 ton Army truck and put your cab on it, if you want all that. Be careful it will end up looking like these these guys. lol
I still have to laugh everytime i see these pic's. LOL
