I have a few questions which are very simple and very basic, some I am pretty sure I know the answer but I would like some verification from you guys that have been in the game for a while.
I am sure most of these question can be answered in my manual and by a quick search but I have been so damn busy with work I barely have time to type this.
Thank you in advance for your time!
Draining fuel....how often are you guys doing this and how much do you drain? My truck sits a lot so condensation may be higher for me....would once a month be the norm for my situation?
When I do drain fuel I do so at the petcock that is located on the main filter housing correct?
I drain when the water sensor says there is water in it or when I change filters and there has NEVER been any water in the separator.
The water is heavier than the fuel so it sits on the bottom and will come out first when you drain so you don't need to drain much to see if there is any water.
