Wastegate on the 38r
With stock injectors, you'll want to clamp it shut. As you add more fuel, you'll want to limit the drive pressure depending on valve spring seat pressure. With my 200/80 sticks, I have the waste gate clamped shut, but I'm running comp 916 springs shimmed at .030 to raise the seat presure. But to be honest, I haven't floored it in the hot tune yet. I need to add a second fuel pump to feed the sticks.
That's the story of my life. I put together a fairly common/proven set of mods and end up full of regret.
Tugly, Is the procedure the same as the stock turbo waste gate or is there a new direction to follow…and refresh my memory on why I need to do this, if you would please…your BuckZooka blasts knowledge proves to be invaluable to a lot of us
The stock setting on the 38R is an anemic 22 PSI and my stocker turbo could do 30 with the red line mod, so this was not an improvement. I still want the wastegate to work, because I feel my old valve springs need something to have their back.
That makes too much sense. I went all high-tech and parked my aircraft-distracting magnet (Mythbusters type) on the turbo until the job was done. If I dropped the clip, it would have fallen horizontally to a predetermined location.
I bought my 38R used and reasonably cheap after searching for awhile. As soon as I got it December 2012, I called Clay and he gave me the same advice Rich is offering. The wastegate comes ridiculously loose from the factory and unless you know it's to tighten it down, you won't see that much of a difference. The PO of the turbo didn't seem to realize that and I think that's why I got it reasonably cheap.
Friendly reminder about the 38R; if the 38R needs to be rebuilt, Garrett does not sell a rebuild kit for the 38R and to facilitate repair, one must return the turbo to Garrett for repair. The center cartridge repair costs almost the same as a new 38R. Why I have no idea.
I believe on the stock turbo we use to set the diaphragm at 12 psi when it starts to open. This let the turbo stay closed to 30psi. What that would be on a 38R not sure, I read on here once it was 50 psi but I think that is to high. What Rich has said makes since and I would probably start there. He dose have his set at 34 psi I think before it opens. If you set it by this method of psi at the diaphragm I for one would like to know what pis you used and what the wastegate opened at. This is a common question and would be nice to know. This can be done with a Mitty vac set on pressure I believe.
I will get a chance to play with it this weekend, and report back..but I gotta say, I had to pass an egg timer just before a merge so I had a little time and gave it a 1/4 throttle and holy geez…i was really surprised, and looked over to my girlfriend, to check on her excitement too….I must had that look..she said, and she was quoting.."stand back girls, I saw him first"
