Top Speed
Old Jan 20, 2015 | 12:11 AM
twigsV10's Avatar
twigsV10
Old Jan 20, 2015 | 09:48 AM
function12's Avatar
function12
I was just point out most people don't know tires are speed rated. Short times above those speeds and you "should" have no issues. Some truck tires were rate for ~84 MPH. You start driving for miles above those speeds and the tire start to shred. Hence the speed governor.
Old Jan 20, 2015 | 10:03 AM
swimmer_spe's Avatar
swimmer_spe
You are right, most people do not know. Fortunately I do.
If I want to sustain higher speeds, like on a track, then Yes, of course, I will invest in properly rated tires.
Old Jan 20, 2015 | 04:59 PM
eriebasin's Avatar
eriebasin
I think driving at over 100 mph on any public highway, road, anything is not necessary and dangerous. That being said, there are places like the track, Isle of Man events, Pikes Peak Challenge, the desert, etc. where you're in a controlled environment or wide open where you can go over 100 if you need to or dare. I like how the Bugatti Veyron does it. In order to reach top speed, you have to stop, open the door and in the door-jam is a keyhole. You have to insert the ignition key and turn to to activate the "sport mode." I like that it precludes you from reaching full speed so you can't get caught up or angry or whatever and go nuts; you have to at least stop. Now, i'm sure the Veyron goes over 100 without doing this as it goes ~258; its an absolutely amazing vehicle!
Old Jan 20, 2015 | 07:17 PM
swimmer_spe
The Veyron, what wet dreams are made from.
Most freeways are built for around 120-140 km/hr
I know that several provinces have 2 lane roads at 100km/hr, some freeways at 110km/hr, and even in BC, 120 km/hr.
Regardless, I am not wanting to sustain much over the speed limit. I am not the ******* passing everyone.
I just want to be able to have more speed if the truck can do it.
Old Jan 20, 2015 | 08:40 PM
seventyseven250's Avatar
seventyseven250
I'd say you have all the information you were looking for, and a bunch you weren't.
remember, we're not just talking to you, but to anyone who might read the thread in the future. So saying some of these things may annoy you, but people like me will continue to do it for a very good reason.
Old Jan 20, 2015 | 08:44 PM
swimmer_spe
I get it.
All I need to do is watch the news. There is always an accident where speed was a factor.
Old Jan 21, 2015 | 12:23 AM
Badass69's Avatar
Badass69
I have seen slightly above 200 km/hr in my one truck because I felt like trying... Tuned 6.2. I know it can go faster but I'm not interested in doing it in a brick designed to go a lot slower than that. Drive shaft critical speeds are a lot scarier than the ratings on tires if you want to make a habit of high speed. Public roads around here are garbage and the speed limit is scary enough at times.
Old Feb 11, 2015 | 12:21 AM
Wrknhonks's Avatar
Wrknhonks
With a Tune ..... you can have more speed
Want more Speed ... enter the world of tunes .... No Governor ... stomp on the 5.0 and you can bottom the speedO out real quick ...probably close to 130 mph .... Speedo only goes to 120 ... but the GPS will give you the real speed ..... Get a tune and re-set the PCM if you need to take it to the dealer ... that simple
Old Feb 11, 2015 | 07:38 PM
srb1194's Avatar
srb1194
This was a rare occurrence but there was probably a little more speed left. I do have custom tune but other than that is bone stock.
Old Feb 11, 2015 | 08:59 PM
seventyseven250
I won't say that I don't speed, because I do, but I don't think I've ever gone that fast in any of my pickups, and to be honest, I don't plan on it.
Old Feb 11, 2015 | 10:24 PM
QwkTrip's Avatar
QwkTrip
It can't be that hard to drive over 100 mph. He took a picture with both hands.
Old Feb 11, 2015 | 11:59 PM
  #28
AlaskanEx's Avatar
AlaskanEx
Bleed Ford Blue
I have never driven with two hands, even auto crossing i use one.
Old Feb 12, 2015 | 12:19 AM
  #29
QwkTrip's Avatar
QwkTrip
This brings back a memory. When I was a kid my dad used to have me grab the steering wheel if he had to do something with both hands. Not often, but it did happen. I thought it was pretty fun!
Old Feb 12, 2015 | 10:08 AM
  #30
gDMJoe's Avatar
gDMJoe
If the option is made to raise/eliminate the PCM's speed limit don't expect any warranty coverage should something go awry. Example ...BTW ... ANY of the current after-market tuners alter the PCM's VIN.
To confirm the vehicle has a Ford Production calibration installed review the PCM calibration filename located in the IDS vehicle log file. The filename (Identified in IDS as PCM_FILENAME) must begin with the prefix letter "D" to be a valid FORD production level calibration.
Even if you de-tune back to stock, that log file will show it was there at some point in time and void your warranty for anything powertrain related.
Other than the issue of a 6,000+-Lb vehicle careening down the highways/byways with the limiter raised/removed (and oh BTW the braking system has not been correspondly been upgraded to match the non-engineered affect), there's that pesky driveshaft critical speed issue. *.below
BUT ... If you're going be an idiot by removing the speed limiter -AND- operate the vehicle at that limit on public highways, then for the sake of your passengers and fellow motorists, have the common sense to minimally UPGRADE THE BRAKE SYSTEM and INSTALL A DRIVESHAFT LOOP so that your stupity doesn't affect them. Also consider installing a metal matrix composite driveshaft.
As for you and you alone - GO FOR IT! Dawin's theory of evolution will eventually kick-in.
----------Drive line Critical speed
What it is –
Every rotating object has a “critical” speed or resonant speed, which is a function of its design, mass and stiffness. This is when the driveshaft is whipping in the middle, rather than spinning on a true centerline. For a driveshaft, this is also called “first bending mode”, indicating the shaft actually bows out into a boomerang shape (on a micro-scale). This first mode bending speed is usually referred to in a driveshaft frequency.
What it does –
The energy stored and released through the deflection of the driveshaft through the resonance creates lateral and vertical accelerations of >10g at the problem frequency, which results in broken transmission extension housings, cases and causes moderate to severe vibration at highway speeds (> 70 mph), particularly with axle ratios numerically higher than 3.27:1. This energy release, when compounded by excessive driveshaft imbalance (some is good, too much or too little is not), companion flange run out/imbalance and excessive driveline angles provides the driver with excessive vibration and boom and tortures the driver and driveline components in general.
Because of this, most vehicles have a speed limiter to prevent from entering this mode and causing damage to the driveline.
Some detail –
As mentioned above, the driveshaft rotates at a certain speed based on rear axle ratio; tire size and road speed, but is independent of engine speed (unless you have a vehicle such as a Porsche 944 or C5 Corvette which utilize torque tubes and transaxles, in which case the driveshaft turns at engine speed).
The factors governing driveshaft critical speed include its material properties (i.e., Bulk Modulus of Elasticity which is roughly analogous to material stiffness), diameter, and length and to a lesser degree, wall thickness.
The only factor you can really modify to affect critical speed is material choice. Length is package-dictated, and diameter is usually constrained by driveline tunnel space as well. The answer then becomes a bit simpler – replace your steel shaft with an aluminum or MMC (metal matrix composite) shaft. Both offer reduced weight, which is key in this frequency range. MMC offers the additional bonus of additional damping and stiffness over a typical aluminum alloy.
As mentioned above, at the frequencies in question, a change in rotational mass has a greater impact on resonant frequency than a change in stiffness does, partly since it is easier to reduce mass than increase stiffness (adding stiffness almost invariably means adding mass -- a vicious circle), but particularly since resonant frequency is equal to the sqrt (k/m), where m is mass and k is stiffness. Here m is a stronger function being the in the denominator of a square root. So you can see that as “m” gets smaller, the resonant frequency “f” gets much bigger.
The use of an aluminum shaft provides a dual purpose – increasing critical speed out of the operating range AND directly reduces the rotational forces since those rotational forces are governed by:
F = mr w**2
Where w is rotation speed, m is the mass and r is the radius at which it is spinning.
This means that a 50% reduction in rotational mass results in 50% less rotational force. So, when a driveshaft rotates out of true, due to run out of the shaft itself or due to trans output shaft or axle companion flange run out, the reduced mass * the radius of gyration (i.e., run out) product is smaller than for the same conditions with a steel shaft.
This becomes important not only at critical speed, but at more normal operational speeds where the effects of run out and mass imbalance are more evident than those of resonance:
For a typical Fox or SN95 Mustang, driveline critical speed is around 95-100 Hz. Using stock tires we have the following:
225-60R15, 225-55R16, 245-45R17 all rotate at 812-820 revs/mile at 60 mph.
This give is 13.5 Hz wheel frequency at 60 mph, and assuming a 3.27 axle, we then have:
812/60*3.27 or 44.25 Hz , driveline frequency.
So, 100/44.25*60 yields a driveline critical VEHICLE speed of 135 mph. A good rule of thumb states that the objectionable driveline forces will start becoming significant at 70% of resonant frequency, so for the case of the 3.27 axle, the boom and vibration may be felt beginning at 95 mph.
Typically, 3.27 axles don’t provide the driver with much to complain about; it is 3.73 and above which create the concerns. Using a 3.73, we find that
13.53*3.73 gives 50.5 Hz wheel frequency at 60 mph (substantially higher than the 3.27)
And the critical VEHICLE speed then becomes
100/50.5*60 or 119 mph.
Taking 70% of 119 mph equals 83 mph, certainly a speed at which some Mustang drivers experience occasionally.
For a 4.10 axle, the “70% speed” is 76 mph!
Compounding this problem are factors like transmission output shaft run out, imbalances and run outs from components such as the reverse sun gear, driveshaft, companion flange and pinion pitch line run out (a torque induced run out created when the pinion tries to crawl up the face of the ring gear involutes).
Combine these factors and the already marginal NVH resulting from proximity to 1st bending (critical speed) and the NVH becomes absolutely agricultural.
The aluminum shaft minimizes the contribution from companion flange run out and the driveshaft’s own run out, directly due the lower mass. The pinion is free to pitch +/- 20 degrees and adding in any run outs of the companion flange or driveshaft at the pinion end results in the driveshaft mass having a large eccentric path to wobble about. It is this path times the mass of the driveshaft, which gives the characteristic boom and vibration at highway speeds.
Thus, as Newton predicted, as mass decreases so will the forces. That is why an aluminum shaft is your friend when coupled to 3.73s.
One side note: that great big mass on your pinion nose, fondly named by driveline engineers after the appendage on a male moose, is tuned to 45 Hz, the frequency at which the 2nd order forces created by u-joints as they rotate, force the pinion to bounce or pitch up and down and shake you by the seat of your pants and create an uncomfortable boom in the car. Once again run outs and imbalances will modulate this 2nd order driveline phenomenon to make it worse, so the moral is, LEAVE THE MOOSEB-, uh, DAMPER ON the pinion nose!
Another item: you CAN expect more axle noise when using an aluminum shaft however, which does not necessarily mean the pinion depth or side shims are incorrect, or that the gear cutting process is flawed. It just means that the aluminum shaft is more willing to “bend” circumferentially, torsionally and in a double hump (2nd bending) much more easily than a steel shaft.
Recall my prior statements at the very beginning about aluminum stiffness vs. steel? Picture a piece of sheet metal ducting. Bend it and it makes a WA-WA sound. That is pretty much what a driveshaft does, but at a much higher frequency – higher than even the dreaded “critical speed” of 100 Hz.
Axle noise will occur from about 350 Hz all the way through 500 Hz, sometimes even higher than that. The energy comes from the teeth meshing at the pinion/ring gear interface. This energy is transmitted to the driveshaft (and suspension components) and makes them deflect in the same sense as a piece of sheet metal goes WA-WA. Aluminum is less stiff than steel and takes less energy to deflect it, so it is far more inclined to make your axle go WOOOOO as you drive down the road at 45-70 mph.
Assuming again a 3.73 axle ratio, which has 11 teeth on the pinion and 41 on the ring gear, the axle noise frequency is calculated as (at 45-70 mph):
815/60*3.73*11 or 557 Hz at 60 mph.
This means the WOOO you hear at 45 mph is about 418 Hz and the WEEEEEE you hear at 70 mph is way up there at 650 Hz. You can’t SEE the driveshaft is bending and breathing and twisting, but it is telling you that precisely that is occurring.
So, now armed with this information, you now understand the basics of your vehicle’s driveline.
