Zf5 extended shift lever?
Old 01-18-2015, 08:27 PM
coreyallan01's Avatar
coreyallan01
coreyallan01 is offline
Evening guys, based on something i saw in Stefans thread I'm wondering if anyone has or has seen a zf5 extended shift lever. My center console is taller than a stock one and I'd like the shift **** to be even with it in 2nd and 4th but keep it looking stock.
Old 01-18-2015, 09:39 PM
fordman67's Avatar
fordman67
fordman67 is offline
My auto shifter is always at the right height lol
Old 01-18-2015, 09:51 PM
coreyallan01
Oh i know!!
Old 01-18-2015, 09:53 PM
MOOSE_MACHINE's Avatar
MOOSE_MACHINE
MOOSE_MACHINE is offline
we'll see if you say that when you get the bts bill lmfao. That auto is doomed. Guts will be torn to shreds lol.
Old 01-18-2015, 10:03 PM
coreyallan01
What does the shift lever look like w the **** removed? Is it threded? Maybe u can just cut the upper portion off another one and use an internal rod w set screws or something?
Old 01-19-2015, 07:31 AM
tjc transport's Avatar
tjc transport
tjc transport is offline
i ain't rite
Received 3,147 Likes on 2,195 Posts
shift **** is a press fit. you would be better off making an adapter to raise it on the bottom. it bolts to the shift tower with 2 bolts. so you could remove the shifter, make a small extender and bolt it to the tower, then bolt the shifter to the extender.
Old 01-19-2015, 08:19 AM
coreyallan01
Thanks Tom, i had it out while doing the clutch so i do know it uses a two bolt deal. If i added to the bottom i couldnt use the boot; its gotta be at the top or in the thick part, remember i want it to look stock.
Old 01-19-2015, 10:19 AM
BBslider001's Avatar
BBslider001
BBslider001 is offline
Yep, me too!! Lol
Old 01-19-2015, 11:57 AM
madpogue's Avatar
madpogue
madpogue is offline
How much do you need to extend it? The boot should accomodate a few inches at least.
Old 01-19-2015, 12:06 PM
91 Dually's Avatar
91 Dually
91 Dually is offline
Yeah, so is mine..n since doing the zf swap, mine has been hanging about eye level on my garage wall..
Old 01-19-2015, 01:04 PM
coreyallan01
I dunno, im at work for another 5 weeks so i cant measure it, id say 3 or 4 inches; not a whole hell of a lot..
Old 01-19-2015, 02:10 PM
FI460's Avatar
FI460
FI460 is offline
Maybe extend it like Tom suggested, and then add a spacer between the trans hump and the boot?
Old 01-19-2015, 02:25 PM
coreyallan01
I hear ya, not a bad idea but not what im after, i want it to appear stock albeit from the extended lenght..
Old 01-19-2015, 05:53 PM
strokin'_tatsch's Avatar
strokin'_tatsch
strokin'_tatsch is offline
If it were me, I'd cut the top half off another stock shifter, cut the top off yours and add however much you want from the other shifter.. ie, weld it, grind down flush with a flap wheel, and repaint the whole thing. I had to weld on mine to run a Hurst **** on it and you can't tell I did anything to it...
Old 01-19-2015, 05:59 PM
coreyallan01
Yup, i think thats the way to go.. There are a few on ebay for cheep... I started the thread to see if anyone had one or has seen one or has pics of one.. Do you know if the thick part is hollow and the thin part is solid?
Quick Reply: Zf5 extended shift lever?
