Sponsored by: Real Truck
starting problem o1 F350
Old Jan 17, 2015 | 11:27 AM
greg1944's Avatar
greg1944
have a 01 f350 7.3 turbo dsl. will not start cold. engine turns over fine. plug into block heater over nite , will start! outside temp does not make difference. have replaced glow plugs, glowplug relay, wireing harness under valve covers. Help. Any Ideas were to go from here?
Old Mar 2, 2015 | 09:24 AM
greg1944's Avatar
greg1944
could it be lousing fuel pressure? starts fine all day till next morning! ideas? any way to check fuel pressure?
Old Mar 4, 2015 | 08:57 AM
SDElwood's Avatar
SDElwood
Beer Fridge Finder
So it could be 75 degrees outside and it still wont start? Have you tried WOT when trying to start it? (Wide Open Throttle)
Old Mar 5, 2015 | 04:52 PM
greg1944's Avatar
greg1944
can be 80 deg, have tried W O T , no luck
Old Mar 5, 2015 | 10:30 PM
tugboatv10's Avatar
tugboatv10
So it won't start with out being plugged in at all? When it does start what does the exhaust look like? Black, white or normal looking exhaust? How long does it take for the smoke to clear up? Hard starting could be a sign of worn injectors. A description of the exhaust may give us a clue.
Old Mar 6, 2015 | 07:44 AM
SDElwood's Avatar
SDElwood
Beer Fridge Finder
And, plugged in, does it fire RIGHT up or does it crank for a while?
Old Mar 6, 2015 | 08:06 AM
greg1944's Avatar
greg1944
starts with just a few seconds of effort, no black exh smoke, some, but not a lot of gray, idles rough for about a minute, clears up. starts the same way all day cold, not pluged in, can crank till battery dead, no start!
Old Mar 6, 2015 | 08:14 AM
SDElwood's Avatar
SDElwood
Beer Fridge Finder
This may sound crazy... but check your oil. Also, what oil do you have in it?
Old Mar 6, 2015 | 08:15 AM
greg1944's Avatar
greg1944
look for? Dello!
Old Mar 6, 2015 | 08:40 AM
SDElwood's Avatar
SDElwood
Beer Fridge Finder
Make sure it is full of oil... 7.3's injectors are oil triggered.
Old Mar 6, 2015 | 09:13 AM
DieselDan10191202's Avatar
DieselDan10191202
i would recommend takeing off both your valve cover and having someone crank your motor over and watch your injector oil spill spouts. Make sure there all oiling right while your cranking. Another good test to do would be to measure your high pressure oil pump pressure. Does your low pressure oil pump gauge on your dash show half or above of oil pressure?
Old Mar 6, 2015 | 09:39 AM
SDElwood's Avatar
SDElwood
Beer Fridge Finder
That's good advice too!
Old Mar 6, 2015 | 05:35 PM
greg1944's Avatar
greg1944
oil pressure on dash gauge is Hi! would it not be higher cold? not pluged in? also oil full and clean
Old Mar 6, 2015 | 06:19 PM
DieselDan10191202
Well buddy a ford powerstroke oil gauge on the dash is a pretty steady gauge. You can not see movement unless you lose all your oil pressure at once. What you need to try is what I mentioned before first. It could be a number of things. I personally think it's oil related. But if you don't want to hook up a gauge to the high pressure oil pump lines and actually monitor the high pressure oil pump pressure to your injectors it would be hard to diagnose and would probley need to be took to a reputable shop. Not everybody understands these powerstrokes. IIt's not just fuel pressure that fires the injectors. Answer me this: what's the mileage? How old is your injectors? Has your U.V.C.W.H. had the retaining clips or the 50 cent mod performed? When's the last time you changed or cleaned your I.p.r. valve?
Old Mar 6, 2015 | 06:22 PM
DieselDan10191202
Smile
Also unplug your I.c.p. sensor on your drivers side valve cover. It's a 3 wire connector. By doing this it'll make a extra 2000 psi of oil pressure. See if that help it.
