Sponsored by: Real Truck
Blower Motor Speed Problem
Old Jan 17, 2015 | 04:54 AM
Mcrafty1's Avatar
Mcrafty1
I have and 07 F250 and the #2 speed for the blower motor don't work (hasn't since I bought it) I read that the most common cause of this is the resistor under the hood on the firewall so I replaced that and still no 2nd speed??? Anyone know where I look next? Motor itself maybe? IDK Thanks.
Old Jan 17, 2015 | 08:02 AM
projectSHO89's Avatar
projectSHO89
Look at the switch and look at the connectors both at the switch and the resistor for signs of corrosion or overheating.
Old Jan 17, 2015 | 08:46 AM
Sully4755's Avatar
Sully4755
Look at the resistor and be sure the coils are not touching each other. They have to be seperated.
Old Jan 18, 2015 | 05:39 AM
Mcrafty1's Avatar
Mcrafty1
The connector at the resistor looked to have been over heated and somewhat rusted/corroded, the switch end looked fine. I cleaned the connector at the resistor but I didn't check to see of the wire for the corroded socket was getting power....I'll check that first, if not is the switch bad? Since the speed control is not in the motor I assuming that if it works on one it'll work in all speeds....Thanks
Old Jan 18, 2015 | 05:42 AM
Mcrafty1's Avatar
Mcrafty1
The resistor is new and looked as it should when I installed it.....I didn't scutinize the coils that much though, I assumed new would be as it should be. If I don't find the problem I'll remove it and check there. Thanks
Old Jan 21, 2015 | 04:32 AM
Mcrafty1's Avatar
Mcrafty1
Can a pigtail/connector for the blower motor resistor be bought for these SD's ? If so does anyone have an outlet and or a part#? Thanks.
Old Jan 21, 2015 | 07:24 AM
projectSHO89
Yes, they're available from Ford, if necessary.
Depending on what truck you're working on, AutoZone may well have it. Go there and plug in your truck's particulars and see if it matches. The basic '07 SD w/V8 uses a Duralast #421, for example, which sells for under $15.
Dorman sells a kit, part # 973-404, that covers a wide range of Fords that includes both the resistor and the replacement pigtail. That kit sells for $16 on Amazon, you might find it stocked at various B&M parts chains. Try Oreilly's first.
Old Jan 21, 2015 | 01:18 PM
jpr38057's Avatar
jpr38057
FYI, if the resistor is bad your blower motor will only work on high speed so I don't think your issue is at the resistor end. Most likely a problem with the switch or connector at the switch.
Old Jan 21, 2015 | 03:08 PM
Mcrafty1's Avatar
Mcrafty1
Thanks guys, I have already replaced the resistor and the connector was melted/ rusted at the point of contact so I followed your advice and ordered a connector from auto zone and I'll be replacing that when it arrives......and if that don't fix the problem it will be the switch after that.
Old Mar 12, 2015 | 01:25 PM
Mcrafty1's Avatar
Mcrafty1
Blower motor speed update......
I know this is a little bit of a time span but I did finally get a warm enough day to replace the connector under the hood at the resister and it DID correct my blower motor speed problem the blower motor now has all four speeds, which is kind of interesting because I tried checking the wires before the plug and I couldn't get power at the plug for the wire that was burnt....decided to change the plug anyway because I already had it and low and behold it fixed the problem.
Old Mar 12, 2015 | 01:31 PM
gasman6674's Avatar
gasman6674
Thanks for the follow up.
Old Mar 12, 2015 | 01:37 PM
Mcrafty1's Avatar
Mcrafty1
No problem, just doing my part
skidaddy
Aug 31, 2021 12:03 PM
wjb21ndtown
2004 - 2008 F150
Apr 25, 2014 03:19 PM
80s Trucker
Jul 2, 2010 09:01 AM
rube
Sep 16, 2008 08:36 PM
Glenn Graham
Nov 29, 2007 11:19 PM
