TRACTION CONTROL
Old Jan 16, 2015 | 12:54 PM
MarauderV8's Avatar
MarauderV8
TRACTION CONTROL
Found behind the cluster the plug for T/C, checked by wiring diagram.
It is possible, that i only to buy a switch and it is plug&play? Or is it necessary to change the ABS module? What do u think?
Old Jan 16, 2015 | 03:19 PM
alloro's Avatar
alloro
Are you talking about the trailer electric brake controller connector?
Old Jan 17, 2015 | 12:26 AM
MarauderV8's Avatar
MarauderV8
no. behind the cluster, close to the message center switch, there was the plug. Checked with wiring, it´s a grey connector with the number C280
Old Jan 17, 2015 | 11:34 AM
alloro's Avatar
alloro
Post your year, make, and model and I'll look it up.
Old Jan 18, 2015 | 02:43 PM
MarauderV8's Avatar
MarauderV8
oh sorry. Lincoln Navigator from 2004
Old Jan 18, 2015 | 02:50 PM
alloro's Avatar
alloro
Here is the connector and it is labeled as being for the traction control switch.
Old Jan 18, 2015 | 09:32 PM
MarauderV8's Avatar
MarauderV8
thank you, but thats what i found out by myself, see post #1 and #3.
My question is, if it can be, that i only have to connect the switch and the T/C will work. Can this be possible?
Old Jan 19, 2015 | 12:47 AM
alloro's Avatar
alloro
I would think if it was that easy then everyone would do it. I can't tell you for sure, but knowing Ford you'll need a different module that supports the traction control feature.
I've attached a PDF showing the wiring to the switch (on the right side). To me it looks like you first make sure fuse #15 is installed, then you can jumper pins 1 and 2 to activate the TC, then use a digital meter across pins 6 and 4 to see if the module reacts.
File Type: pdf
Old Jan 20, 2015 | 12:39 PM
MarauderV8's Avatar
MarauderV8
uff, think the best to do is to purchase a switch and to try.... ;-)
khite
Jun 13, 2019 03:49 PM
ligito
Aug 10, 2016 12:18 PM
whirlybird
All Things Towing
Jun 3, 2015 06:03 PM
Masstech
Jun 15, 2012 06:36 PM
