Code help U1900
Old Jun 14, 2012 | 09:28 PM
Masstech's Avatar
Masstech
Code help U1900
2010 explorer sport trac
Code u1900 no comms from apim air bag light on
Trucks has eclipse navigation with pswic steering wheel controls and a remote starter the bypass is an udatalink adsalko. Truck also has trailer harness and trailer brake. The aftermarket accessories have been installed for 33,000kms.
Old Jun 14, 2012 | 10:17 PM
shorod's Avatar
shorod
Have you checked the fuses in the interior and battery fuse panels?
-Rod
Old Jun 15, 2012 | 04:38 PM
Masstech's Avatar
Masstech
No I have not thanks for the post I will have to check that.
Old Jun 15, 2012 | 06:36 PM
aquanaut20's Avatar
aquanaut20
Your vehicle has a data line that runs between modules. It's called a CAN (controlled area network) bus. The data bus has failed and the modules can no longer communicate with each other. This is usually caused by a short in one of the modules that sends voltage down the data bus instead of digital data. To diagnose this yourself you'll need a good shop manual to find where all the modules are. Try either alldatadiy.com or eautorepair.net. Then unplug one module at a time until the problem goes away. That will be the shorted out module.
If you disconnect all the modules and the problem still exists, then you have a shorted or open CAN bus. But that's fairly rare.
Normal Operation
The high speed CAN has an unshielded twisted pair cable, circuits 1908 (WH) and 1909 (BK). The anti-lock brake system (ABS) module, the instrument cluster, the powertrain module (PCM) and the trailer brake controller are all on the CAN. The total resistance values from the module to the data link connector (DLC) must not be more than 5 ohms. If the resistance is more than 5 ohms there is an open in one of the CAN circuits, damage to the DLC C251, damage to one of the communications network module connectors, or damage to an in-line connector.
ghuertas
2009 - 2014 F150
Jun 13, 2019 07:41 AM
z31freakify
Aug 17, 2017 08:46 AM
BRay09
Dec 17, 2015 01:37 PM
Ford Fx4
2009 - 2014 F150
39
Mar 28, 2012 09:15 PM
