Large Truck My truck is bigger than yours. The forum for 2+ ton trucks (all years), COE's, Louisville's, Big-Job's etc.
2 new questions
Old Jan 16, 2015 | 08:16 AM
Grizzly93's Avatar
Grizzly93
2 new questions
i got the wiring diagram Thanks.
1. the wiring diagram doesnt show insturment lights and they dont come on when switch is pulled. yes the bulbs are good.
2. any one know the number for the marker lights
Thanks
Old Jan 16, 2015 | 08:13 PM
dmanlyr's Avatar
dmanlyr
Have you replaced the headlight switch? the instrument lights are powered by this switch, but also go thru a reostat that dims or brightenes them. Not uncommon at all to have that part of the switch go bad.
The marker light bulbs were a #97 as I remember on my C600
D~
Old Jan 16, 2015 | 08:39 PM
Grizzly93's Avatar
Grizzly93
All the switch's are new. I found a bad wire after a lot of wire checking. And thanks for the bulb #
Old Jan 17, 2015 | 03:32 PM
dmanlyr's Avatar
dmanlyr
Glad to hear that you got it repaired!
D~
Old Jan 17, 2015 | 06:26 PM
Grizzly93's Avatar
Grizzly93
Thanks. The only thing I have to figure out is why when the blinkers are on the opposed tail light flickers a little. Any ideas
Old Jan 24, 2015 | 07:18 PM
papasmurf40's Avatar
papasmurf40
Possiblly a ground issue?
Old Jan 24, 2015 | 07:21 PM
Grizzly93's Avatar
Grizzly93
Yes that's what I thought also. I only found 1 ground from the body to the block so I ran another from the block to the frame. Should I run another somewhere?
Old Jan 25, 2015 | 01:05 AM
papasmurf40
Usually body to block, block to frame and body to frame should cover it.
Old Jan 25, 2015 | 04:05 PM
85e150's Avatar
85e150
Add dash to body/frame for a ground. Not sure how a dash isn't attached in such a way as to be grounded with the body, but we did have that issue in a '67 El Camino. WAG, serving suggestion....
travelingman55
Dec 24, 2012 11:14 PM
Ford7000
Large Truck
Aug 5, 2011 07:15 PM
sd59f100
Jan 29, 2009 01:46 AM
mvtofino
Nov 17, 2008 09:27 AM
broncobillyII86
Bronco II
Jan 5, 2007 02:00 AM
