Talk striction please
Old Jan 16, 2015 | 12:11 PM
Bonanza35's Avatar
Bonanza35
Guys this is just what I wanted. Toreador_Diesel thanks for the straight talk also. That's what I was thinking on the FICM tune because of the weight I do tow. Having to much EGT's with that weight will just make things worst. I'll have to order some products now for the oil and fuel and give it a try. It mitt be a while before I know but will report back with I find also. This ended up being a great thread to read.
Old Jan 16, 2015 | 04:13 PM
diesel_dan's Avatar
diesel_dan
Archoil 6400-D?
Interesting that I don't see much mention of this PEA (think Techron) fuel system cleaner...? Has anyone tried it? Do folks even know it exists?
I'm just asking -- I bought some for my Bobcat to try and fix a different issue, so I can't say what it would help stiction-wise in our 6.0s, but it is a super-cleaner (concept) additive also.
Somebody has had to have tried it by now... (sorry, I've taken probably 6 months off the forum )
Old Jan 16, 2015 | 05:34 PM
Iaff113's Avatar
Iaff113
Originally Posted by diesel_dan
Interesting that I don't see much mention of this PEA (think Techron) fuel system cleaner...? Has anyone tried it? Do folks even know it exists? I'm just asking -- I bought some for my Bobcat to try and fix a different issue, so I can't say what it would help stiction-wise in our 6.0s, but it is a super-cleaner (concept) additive also. Somebody has had to have tried it by now... (sorry, I've taken probably 6 months off the forum )
I cant even find info on it other then the AR6400
Old Jan 16, 2015 | 05:54 PM
diesel_dan's Avatar
diesel_dan
Wasn't available in the US 'til middle of last year (it had been out in Europe for awhile). I bought mine from an Archoil dealer and 6.0 owner that I contacted off another forum. Mine came from the 1st batch he received in July last year...
Here's his order page, it's near the bottom:
Home
BTW: I have no affiliation with Archoil or any other reason to bring this up other than curiosity
Old Jan 16, 2015 | 07:30 PM
Iaff113's Avatar
Iaff113
Wasn't available in the US 'til middle of last year (it had been out in Europe for awhile). I bought mine from an Archoil dealer and 6.0 owner that I contacted off another forum. Mine came from the 1st batch he received in July last year... Here's his order page, it's near the bottom: Home BTW: I have no affiliation with Archoil or any other reason to bring this up other than curiosity
Can't open the page. So is it tHe archoil 6400?
Old Jan 16, 2015 | 08:18 PM
Corner Gas's Avatar
Corner Gas
Originally Posted by Bonanza35
Colin, how long after using RevX did it take to notice the difference? 50 miles, one oil change, and I guess it's kind of the thing that has to go in every oil change? It just sucks with only 80K miles on the truck.
I noticed a difference after the first time I drove it. After about 2500 miles it was back to normal. As I understand it you do not have to add it every oil change, just when you need it.
Old Jan 16, 2015 | 08:34 PM
KDAVID1's Avatar
KDAVID1
[QUOTE="Toreador_Diesel;15000173"
70+ mph
Maybe that's my problem. I'm mostly at 65 with occasional periods of 70. I have 3000 on it so I I suppose another 2000 will do the trick?
2006 F350 4X4
Old Jan 16, 2015 | 08:51 PM
Tennesseepowerstroke's Avatar
Originally Posted by Reverend Jim
Bonanza, I had a hard start condition when cold, ficm was good so I flushed the oil and put in 5w40 Rotella T6 and tried the Archoil. I drove it to work,(18 miles), and parked it overnight with temps around 15*f. I didn't plug it in so I could see if this stuff would make a difference. It would normally take the truck about 8-10 minutes to finally start in that temp. That morning, and ever since, the motor only turns about 2-3 seconds and fires right up. I will use it every other oil hange from now on.
I wonder if the 5w40 Rotella or the Archoil made the difference? Mine starts easily at any temperature I have tried to start it, but it sure does start up smoother in temps at 25 and above.
Old Jan 16, 2015 | 09:18 PM
Toreador_Diesel's Avatar
Toreador_Diesel
FTE Leadership Emeritus
[QUOTE="KDAVID1;15002075"][QUOTE="Toreador_Diesel;15000173" 70+ mph Maybe that's my problem. I'm mostly at 65 with occasional periods of 70. I have 3000 on it so I I suppose another 2000 will do the trick? 2006 F350 4X4[/QUOTE]
Run the full 7,500 mile interval with mostly freeway time and that should do the trick. Engine seems to run hotter at 2000-2200 RPMs. Atleast on my truck it does...
Old Jan 16, 2015 | 09:50 PM
diesel_dan's Avatar
diesel_dan
I tested the link and it still works for me, but no matter -- it is not just the 6400 but 6400 with a dash "d" = AR6400-D
Old Jan 17, 2015 | 05:26 AM
KDAVID1's Avatar
KDAVID1
Mine does too around 205 206 mostly on the EOT at 65 and around 1750 rpm. Surely that's hot enough for that stuff to work. Good thing is I can wait an extra 2500 miles before the oil change
2006 F350 4X4
Old Jan 18, 2015 | 02:41 PM
xaviar's Avatar
xaviar
Well after reading this post and my cold morning rough starts has come back. I'll give the hot shots extreme a shot... I've used the Archoil 9100 before and have been satisfied with it. I'll post my results after a tank of fuel. Thx for the info.
Old Jan 18, 2015 | 02:55 PM
  #28
Bonanza35's Avatar
Bonanza35
It's nice to bring this back up once in a while. I ordered a few things also.
Old Jan 18, 2015 | 11:55 PM
  #29
BryanStein's Avatar
BryanStein
I'm running 6400 now. Have about 800 miles on it. I still have stiction, but I don't feel enough time has passed.
However, I was not aware of the "-D" difference. Now I'm curious as to what I'm running.
Old Jan 19, 2015 | 04:40 AM
  #30
Iaff113's Avatar
Iaff113
The first link is D the second is just 6400 if you care to read http://www.archoil.com/wp-content/up...ta%20Sheet.pdf
