94 Explorer knocking problem
Old Jul 21, 2003 | 10:59 AM
Ben Nemec's Avatar
Ben Nemec
Unhappy 94 Explorer knocking problem
help, does anyone have any idea why my 94 ewplorer is knocking. I have tried cleaning the MAF, changing the EGR valve, re tightining the lower manifold bolts and every oil and gas treatment made. they all helped but the knock is still there.
Old Jul 21, 2003 | 11:24 AM
mrshorty's Avatar
mrshorty
Some other possible causes:
Dirty cylinders: Try decarboning them (Seafoam, water, or other cleaner sucked in through the intake manifold. check around for more detailed instructions)
Other vacuum leak, or a hole in the intake tube downstream from the MAF. Also, tightening the intake manifold bolts won't fix a truly bad gasket. If you find that other fixes don't work, you may need to replace that gasket.
Dirty fuel injectors. I know you've tried every gas treatment made, but sometimes the best way to clean injectors is to remove them. This could be done while replacing an intake manifold gasket.
Spark knock is usually caused by the engine running a little lean, so anything that effects fuel/air mixture could contribute. Check O2 sensors and ECT sensor (causes to run lean if it's reading too hot). Also check fuel pressure. If the pressures too low, it will run lean.
Tecride1
Oct 2, 2015 10:58 PM
trvctyrich
Dec 9, 2011 03:03 PM
tgen17
Modular V10 (6.8l)
Apr 27, 2011 06:49 PM
Ranger256
Escape & Escape Hybrid
Dec 30, 2005 01:41 PM
explorerguy
1983 - 2012 Ranger & B-Series
Jan 5, 2003 09:01 PM
