Steering Column Slop.
Old Jan 15, 2015 | 11:00 AM
Johnny Be Cool's Avatar
Johnny Be Cool
Just received a 1974 F250 HB w/ manual steering. The end of the steering shaft that is in the engine compartment side has a white plastic sleeve hanging from it. I can take the shaft on that end and move it up and down.
Does the plastic sleeve hold it in place or is there something else that is causing the slop.
Thank you!
Old Jan 15, 2015 | 11:24 AM
77&79F250's Avatar
77&79F250
Moderator & parts slinger
Pretty sure that white collar goes back in the end of the steering shaft. And will stop the play, also ck the steering u joint.
File Type: pdf
Old Jan 15, 2015 | 11:59 AM
Johnny Be Cool
Yes, I think its part number 3C773. It's not broken just hanging down.
If I slide it back up and it doesn't stay, do you think a hose clamp would be good to use to keep it from sliding down?
Is that the only part that is allowing the shaft to wiggle within the column?????
Also, thank you for taking the time to post up the exploded view!
Old Jan 15, 2015 | 12:05 PM
hickory1991's Avatar
hickory1991
That white plastic piece should also have a bearing in it that goes around the steering column shaft. There should be tabs on the white collar that snap into the housing. They may be broke or weak.
Old Jan 15, 2015 | 12:08 PM
77&79F250's Avatar
77&79F250
Yes that should work if the plastic side clips on the side are broke off. I think there is a bearing up in there too? Here are some more diagrams for you....
https://www.ford-trucks.com/forums/1...then-some.html
And I am only the copy and re-paste in one spot guy, I collect them from other FTE members.
Old Jan 15, 2015 | 05:11 PM
Johnny Be Cool
I had a hard time getting the white plastic sleeve back on but as soon as it was on it fell off. Are these replaceable. Do I need to pull the column or steering sector rod.
Old Jan 15, 2015 | 05:17 PM
hickory1991
Tabs that hold it in are either worn or broke. Can be replaced and you may have to back off column to separate from shaft. I think bronco graveyard sells a metal replacement for it.
Old Jan 15, 2015 | 08:22 PM
77&79F250's Avatar
77&79F250
What happened to the hose clamp idea? Remove the steering shaft (in the engine compartment) and then put a new one in.
Old Jan 15, 2015 | 09:34 PM
Johnny Be Cool
Yes were right, I was too much in a hurry to take it around the block for the first time. I think the center bushing is missing so I believe I'll end up buying a new one. It looks like an easy fix and cheap price on the part.
Old Jan 16, 2015 | 03:54 AM
77&79F250's Avatar
77&79F250
I believe (JBG) Jeff's Bronco Graveyard has them?
Early Bronco Restoration Full Size Bronco Restoration Classic Ford Bronco Parts For Sale
knucklecars
Aug 8, 2016 09:11 PM
hawk1959
13
Oct 15, 2014 12:05 PM
ghanaguy
Dec 12, 2012 08:25 PM
BuickBrian
Nov 11, 2008 12:03 PM
