Fe timing cover
Old Jan 15, 2015 | 12:14 AM
Whitepos72's Avatar
Whitepos72
Fe timing cover
Im putting a cam in a friend of mines 390 for him and theres a piece on the crankshaft that i found after pulling the balancer thats too bit fir the cover to slip over and i cant get it off and clue?
Old Jan 15, 2015 | 12:41 AM
351Cleveland C4's Avatar
351Cleveland C4
That doesn't make any sense. If the FE is anything like my cleveland, once you have the balancer off, the crank is only like 1-1/2" diameter. The crank seal rides on the balancer on my engine. So there is absolutely nothing left that would prevent the timing cover from easily passing over the crank. As seal diameter is close to 2" or so.
Old Jan 15, 2015 | 01:44 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Behind the balancer (6312) is its spacer (6359). The spacer and the balancer are retained in place on the crankshaft with a 1/4" x 3/4" keyway (358963-S).
The spacer, keyway, oil slinger (6310) and timing cover are the same for all 1958/76 FE engines.
The timing cover seal (6700) is the same for all 1963/76 FE engines.
Old Jan 15, 2015 | 01:46 AM
Whitepos72's Avatar
Whitepos72
how do i remove it?
Old Jan 15, 2015 | 03:46 AM
willowbilly3's Avatar
willowbilly3
They usually slide right off. It might be varnished on or some one previous damaged it in some way. I would say try a bearing clamp and a puller.
fordboy300
Mar 25, 2012 01:47 PM
jemini
Nov 8, 2010 03:09 PM
knuckle
Apr 7, 2009 01:26 PM
77fordf-150
Feb 8, 2007 11:16 PM
