Smoke - is my engine tuned?
Old Jan 13, 2015 | 11:52 PM
F357's Avatar
F357
A few weeks ago I bought a 2004 F350 ex fleet truck for cheap because I wanted to put the engine in my other truck, which is blown. Turns out I like this truck and I probably won't steal the engine.
Anyway, I've noticed that if I stomp on the throttle really hard, I get a puff of black smoke. Will a stock 6.0 engine do that? Is that a sign that my engine has been tuned? It still has a full stock exhaust, cat and all. This one seems to have much better throttle response than my other one did. Maybe it just feels faster because it's a light weight single cab 2WD...
Is there any other way to tell if it's not running the factory tunes? Seems odd that this truck would be tuned, it is totally stock, fleet truck. As far as I know I am the second owner.
Or does the smoke indicate any other problem? It seems to run really good otherwise. About 190,000 miles. My other 6.0 never smoked.
Old Jan 14, 2015 | 01:34 AM
Jeff Watts's Avatar
Jeff Watts
Not a big deal in my mind. Just over-fueling for a second while the turbo catches up to the amount of fuel you're putting to it.
Old Jan 14, 2015 | 03:51 AM
F357's Avatar
F357
The question is "why"??? That is not normal for a 6.0 engine. All the stock ones I've seen never have any smoke at all.
Old Jan 14, 2015 | 03:57 AM
Jeff Watts's Avatar
Jeff Watts
That depends on how hard you're romping on the throttle. The turbo runs off of the exhaust gases, and spools up to increase the air going into the engine.
Black smoke is unburned diesel.
When you romp on it, you're putting more fuel into the engine than it is currently receiving enough air to properly combust.
It's called "turbo lag".
If you think there's a problem, then look at the turbo. It may be in need of a rebuild.
Old Jan 14, 2015 | 04:03 AM
F357's Avatar
F357
In my other stock 6.0, it would never smoke no matter how hard you hit the throttle. Is this not how stock 6.0s normally are?
Old Jan 14, 2015 | 06:58 AM
turbotuner's Avatar
turbotuner
I would suggest the elm327 and torque app to get the variable geometry turbo. If you think its to much the vanes in the turbo might be sticking.
Old Jan 14, 2015 | 07:15 AM
69cj's Avatar
69cj
If its running that good, I wouldn't screw with it. I could occasionally get a puff of smoke on my 6.0 under sudden hard acceleration. Remember, If it ain't broke don't fix it.
Old Jan 14, 2015 | 12:30 PM
jseim44's Avatar
jseim44
My 05 started smoking like you describe on take off. I thought it was normal at first as it only did it when I punched it taking off. Then I noticed it was starting to do it more and more. I started watching my boost and found it was lagging behind bad at first. I googled the cleaning procedure and pulled the turbo. That made a world of difference. If you have an International truck dealer around your area they have kits that include everything you need to remove, clean, and re-install turbo. Remember, our 6.0 is their VT365.
However, if it's only minimal smoke, and doesn't continue to get worse then I wouldn't worry about it.
A ScanGauge or the Torque app or something similar is a good investment for these rigs.
Good luck with your 6.0! I love mine!
Old Jan 14, 2015 | 01:25 PM
F357's Avatar
F357
It's interesting that you say there could be something with the turbo. I notice on this truck I don't feel the constant turbo lag the stock 6.0 is known for. That's another reason I thought it might be tuned. Also getting 18-20 MPG on the highway.
I can't tell if this truck is faster because it is smaller and weighs less than my other one or if it's because the engine is stronger.
Old Jan 14, 2015 | 02:44 PM
69cj's Avatar
69cj
Unloaded it's not unusual to get 18 to 20 mpg on the highway.
Old Jan 14, 2015 | 02:52 PM
Tunedsmoke's Avatar
Tunedsmoke
Smile I like diesels but...
My little experience with diesels tells me to worry if they do not smoke when pushed hard. As far as being tuned...run a code check on the beast if you suspect something is amiss.
Old Jan 14, 2015 | 10:57 PM
mhoefer's Avatar
mhoefer
I wonder if EGR valve is starting to stick, sensors plugged a bit. This is what happened to me, it was EGR valve and cleaning MAP, MAF, IAT2, EBP. That's without any mods, never any smoke, even with Atlas 40 FICM tune, still negligee, barely ever see it, I only go full throttle most of the time.
You could also need to clean VGT on turbo, or have VGT valve failing but if this is the only symptom perhaps just watch it...
Your single cab, will be lighter and peppier too. My crew short box single wheel 4*4 weights in 8780 lbs with full fuel tank, driver and tool box full.
doombugie
Jul 15, 2012 03:52 PM
N4TECguy
Oct 25, 2010 11:11 PM
steinbill
Apr 29, 2008 08:46 AM
weekendwarriorfsw32
Aug 27, 2007 10:34 PM
slc10844
Oct 18, 2004 05:34 PM
