Fuse Blowing Problem
Old Jan 13, 2015 | 05:38 PM
Plowboy34's Avatar
Plowboy34
fuse #11 in the battery junction box under hood keeps blowing, the last time I put a fuse in it blew immediately, key was off and lights off. Fuse is for parking lights, dash light and I/P(whatever that is) and switch illumination lights. Just hoping maybe someone had same problem before I have to start following all wires to find bad spot. May just put in piece of metal and watch for smoke...
Old Jan 14, 2015 | 07:25 AM
pawpaw's Avatar
pawpaw
Is problem with the 91 F-250 in your profile????
Old Jan 15, 2015 | 03:21 PM
Plowboy34's Avatar
Plowboy34
I guess the vehicle info would be helpful wouldn't it. No it's not the 91 F-250 it is a 00 Ranger
Old Jan 15, 2015 | 03:49 PM
pawpaw's Avatar
pawpaw
Ok, a 00 Ranger, on my 99 #11 is a 15 amp mini fuse for the park lamps relay & main light switch, so what happens if you remove the park lamp relay????
I believe IP may = Instrument Panel.
Here is an online link to your 2000 owner manual that shows the same #11 fuse nomenclature as my 99 does. http://www.fordservicecontent.com/Fo.../00ranog1e.pdf
stemo76
Mar 4, 2016 09:45 AM
Wmeyer
16
Jul 25, 2005 07:57 PM
ryan_37
Electrical Systems/Wiring
Jul 20, 2004 09:06 PM
Skagit
Nov 16, 2003 08:25 PM
cbeaur
May 9, 2003 03:54 PM
