Bellhousing Question
Old Jan 13, 2015 | 11:48 AM
49fordv8f4's Avatar
49fordv8f4
Did the '53 V8 have a one piece, full bellhousing when used in the trucks? As opposed to the two piece 3" bell on the engine and half bell on the transmission. If so, was the T9 spur gear 4-speed ever installed on that bellhousing?
Mark
Old Jan 13, 2015 | 12:26 PM
ALBUQ F-1's Avatar
ALBUQ F-1
Looks like all BH's were 1-pc, I don't see any 2-pc BH's in the catalog. But I don't see the T9 used in any models 53-56.
Old Jan 13, 2015 | 04:00 PM
49fordv8f4's Avatar
49fordv8f4
Thanks Ross, that is exactly what I suspected.
Mark
Old Jan 13, 2015 | 04:04 PM
ALBUQ F-1's Avatar
ALBUQ F-1
I was under the impression that the T98 had the same bolt pattern to BH as a T9? But the 53-on BH's are deeper than the 2-pc BH's.
Old Jan 13, 2015 | 04:31 PM
49fordv8f4's Avatar
49fordv8f4
The '47-'52 T9 and the '48-'52 T98 transmissions are identical from the transmission case forward. The half bell on a T98 and T9 are identical with the exception of the hole for the bearing retainer. The flange on the T98 retainer is about an 1/8" larger in diameter than the one in the T9. The input shaft on the '53-'56 T98 is longer than the earlier ones.
I was asking the original question because of the discussion we are having on the thread '51 F3 Syncro transmission. I was trying to figure out what kind of T9 Danbear was talking about that would fit the one piece bellhousing.
Thanks again, Mark
dmanlyr
Sep 6, 2010 12:52 AM
55 f350
Feb 5, 2009 11:59 AM
mitchy
Feb 3, 2008 09:12 AM
nulloutput
Engine Swaps
Dec 8, 2004 03:06 PM
pcmenten
May 26, 2002 11:09 PM
