Fuel line problem
Old Jan 12, 2015 | 09:39 PM
Beachboss's Avatar
Beachboss
Fuel line problem
So I bought a 88 f250 4x4 5 speed 460. I was told it had been converted to a holly carb. The problem is the fuel lines have been distroyed. Only the rear tank is plumbed and the fuel pump is an aftermarket inline pump mounted to the frame. I read that the 7.5 460 only needs the low pressure in tank fuel pump. Is this true? Also how do I plumb the return lines?
Old Jan 13, 2015 | 04:49 AM
Zip's Avatar
Zip
First off welcome to FTE. A good place to pose your question may be here. It should be a good starting point at least.
1987 - 1996 F150 & Larger F-Series Trucks - Ford Truck Enthusiasts Forums
Old Jan 13, 2015 | 02:47 PM
1Aauto's Avatar
1Aauto
Former Vendor
Thanks for joining, it's great to have you here.
Tony
tmeckes03
New Member Introductions
Sep 29, 2016 08:38 AM
52deder92
Oct 28, 2014 01:48 PM
clydeford
May 10, 2009 01:20 PM
jjsether
Dec 27, 2006 11:51 PM
