I tow with the Atlas 40, 8k tow, 155's, and a Power Max. I think you will be fine with your combo I also have a few other trucks out there with stock turbo and injector combos with the Atlas 40 and 8k tow tune.
The only tune writer I use is Gear Head, so we are comparing apples to apples on my customers trucks.
Let me know how you like that econ tune. I tow 15K so I haven't decided yet what I want. It's all stock except all the bullet stuff and heads studs I've done.
I will. Still not entirely sure which one I am going to do. I guess I just don't understand the logic.
The information I was provided states that the ECO tune and the Atlas 40 will feel the same when I drive under normal conditions. However, there is only a 10 hp difference under load.
If that is the case why have the Atlas 40 as an option? I will have to engage with PHP to clear the FOG. I have not had much luck in contacting them.
