Transmission match
Old Jan 11, 2015 | 09:16 PM
Whitepos72's Avatar
Whitepos72
Transmission match
My 390 blew a head gasket today and ive got a built 351w sitting around will it bolt up to the trans or are big and smallblock transmissions different?
Old Jan 11, 2015 | 09:17 PM
351Cleveland C4's Avatar
351Cleveland C4
They're different.
I'm assuming you have a C6.
One option you have is to find a small block C6 trans, or a C4, and swap it in with your 351W. They can be had pretty cheap on Craigslist, and are cheap and easy to rebuild if they need to be. Also they perform very well, and are very durable transmissions.
Another option, is to swap in an AOD overdrive tranny behind your 351W. That would cost a little bit more, but if you drive on the highway a lot, or have low rearend gears, it can be worth it.
or, swap in any number of Manual gearboxes,
OR! The most practical, easiest, most boring way, just Fix the 390...
Old Jan 11, 2015 | 09:18 PM
ultraranger's Avatar
ultraranger
Block transmission pattern is different and engine perches are different.
Old Jan 11, 2015 | 10:29 PM
Whitepos72's Avatar
Whitepos72
Does the aod have any electronics that have to be accounted for? And yea fixing the 390 would be easiest but whats the fune in that!
Old Jan 11, 2015 | 10:32 PM
HIO Silver's Avatar
HIO Silver
Originally Posted by Whitepos72
Does the aod have any electronics that have to be accounted for? And yea fixing the 390 would be easiest but whats the fun in that!
An AOD? . nope... no trons til around '94 or so depending on the donor.
Here is info for your cranial consumption if going AOD: Ford AOD Overdrive Transmission | Hemmings Motor News
Old Jan 11, 2015 | 10:40 PM
Whitepos72's Avatar
Whitepos72
Thanks i think im gonna try to get a c6
Old Jan 11, 2015 | 10:43 PM
351Cleveland C4
C-4 would almost be better. They are lighter weight, take less power to drive. They can be built to handle over 1,000hp so they are plenty strong.
I used to have one in my truck. And I still would, but I went AOD.
Old Jan 11, 2015 | 10:44 PM
HIO Silver's Avatar
HIO Silver
What about an E4OD?
Old Jan 11, 2015 | 10:47 PM
351Cleveland C4
Small block E4OD would work. But they're electronic.
Old Jan 11, 2015 | 11:48 PM
Whitepos72's Avatar
Whitepos72
Will the aod goi in factory trans mount and work with stock driveshaft?
Old Jan 12, 2015 | 04:17 AM
jowilker's Avatar
jowilker
Whitepos72, Any reason not to replace the head gasket and keep it going?
John
Old Jan 12, 2015 | 10:01 AM
351Cleveland C4
It uses the c4/c6 mount, and it should work with your existing driveshaft. (My c4 was the same overall length) but the mount and crossmember need to be moved a little more than 2" back on the frame.
Old Jan 12, 2015 | 12:03 PM
Whitepos72's Avatar
Whitepos72
Jowilker im still looking at pros and cons of the swap and fixing the head gasket but im probally gonna put the 351 in because its just sitting around and should make around 450hp as opposed to my 200 ish 390 plus it weighs less and is easier to get parts for
Old Jan 12, 2015 | 05:33 PM
jowilker's Avatar
jowilker
You might be happier with that engine in a car.
John
Old Jan 12, 2015 | 05:51 PM
351Cleveland C4
Originally Posted by jowilker
You might be happier with that engine in a car. John
Like a TORINO!!!
