HELP ME!! Cant move column shift lever
Old Jan 11, 2015 | 10:22 PM
Spktyr's Avatar
Spktyr
Originally Posted by MRFIESTAS
Ok, that s Rear Antilock Brake System.
How would that cause the shifter to malfunction?
As someone else pointed out, it could be something wrong with the brake electrical system, such as a blown fuse.
Old Jan 12, 2015 | 05:42 AM
dixie460's Avatar
dixie460
That's a great idea on how to shift it w/ the fuse out. I will certainly keep that in mind if you think it will work.
Also, any other thoughts I would appreciate.
Not only have I personally tried it but that's also how Ford designed it to work! If you look in the owner's manual it tells you do to just that if you're ever stuck in park.
Originally Posted by Spktyr
I just disconnected the column shift interlock on mine, it's easy. The particular mechanism Ford used wasn't very good and had problems disengaging when it got old, so no loss.
Yep, all you have to do is unplug the interlock solenoid under the column. Unless you're like me and don't like useless parts hanging out on your truck. I actually pulled my column out and tore it down so I could remove ALL the interlocks from it. No shift lever lock, no steering wheel lock, nothing to bind up and ruin my day at all. I always use my parking brake anyway.
I did some reading to find that the light is flashing 15X which the published chart says its had a memory failure. How do I reset it or get it to remember again?
Memory in this case probably means an EEPROM (Electrically Erasable Programmable Read-Only Memory) failure. That is, the RABS controller's internal memory chip has either failed or is no longer functioning due to another internal problem. The "normal" way that someone would fix this is to replace the RABS controller but if you're good with electronics you can crack it open to have a look and replace the failed part, repair the broken solder joint, whatever it wrong with it.
Old Jan 17, 2015 | 11:15 PM
MRFIESTAS's Avatar
MRFIESTAS
Well the next day I was all set with a box of fuses in case they blew and I started the truck and the ABS light wasn't on and therefore wasn't flashing and haven't had a issue with it since. Only thing I can figure was snow got into the rear brakes and the next day it was ok and after loosing its memory it regained it.
Old Jan 18, 2015 | 12:39 AM
Fmfl's Avatar
Fmfl
the fuse blowing would cause it to loose memory because it no no longer had any power going to the memory unit
chevma-67
1997 - 2003 F150
Aug 21, 2008 11:06 AM
rafterman191
Electrical Systems/Wiring
Jul 14, 2008 06:53 AM
murphf-150
Mar 10, 2008 07:49 PM
jhimmelsbach
Feb 3, 2008 08:24 PM
gp_supercrew
1997 - 2003 F150
Sep 22, 2007 04:25 PM
