Sponsored by: Real Truck
ATF change?
Old Jan 10, 2015 | 05:29 PM
427ford's Avatar
427ford
ATF change?
'04 F250 FX4 PSD:
If I drain fluid via pan plug, aproximatly how many quarts can I expect to replace?
Old Jan 10, 2015 | 07:37 PM
Mike189677's Avatar
Mike189677
About 8 quarts
Old Jan 24, 2015 | 02:07 PM
427ford's Avatar
427ford
Thanks Mike.
Old Jan 24, 2015 | 07:59 PM
05F250DSL's Avatar
05F250DSL
You may want to swap the external filter while your at it.
Old Jan 25, 2015 | 10:10 AM
speakerfritz's Avatar
speakerfritz
I would recommend a more frequent drain interval if you are only going to use the drain plug since it will take numerous drain and fills to purge out old fluid at 50% replacement per drain. basically, you will always have old fluid in there.
Old Jan 25, 2015 | 10:42 AM
Truckie256's Avatar
Truckie256
By the time you do multiple pan drains.. its probably better to just get a mechanic to use the machine and do it all at once...
made a big difference on my police interceptor
Old Mar 1, 2015 | 09:35 AM
427ford's Avatar
427ford
Good idea.
rvpuller
1997 - 2003 F150
Sep 13, 2015 06:55 AM
Robby Nash
Oct 22, 2013 03:38 PM
Schmitty133
Nov 11, 2010 07:30 AM
TallPaul
Aerostar
18
Jul 25, 2007 11:50 PM
jade97
Modular V10 (6.8l)
Apr 22, 2003 12:28 PM
