ABS, VSS, Speedo, something's JACKED and Godzilla doesn't like to stop
Old 01-15-2015, 01:37 PM
fakirone's Avatar
fakirone
fakirone is offline
So the dealership now says that the master cylinder needs to be replaced.
SO, I picked up a new one from O'Reilly and will try to get it in this weekend. We'll see.
I still find it very coincidental that this was NEVER an issue before I had them do the brakes, and there's no way that a new master cylinder will solve the brake light issue which started at the same time.
Anyways, I'll see what they say the dealer says the issue is once I replace the master cylinder.
Old 01-15-2015, 03:51 PM
daddylee100's Avatar
daddylee100
daddylee100 is offline
Following..
My brakes used to lock up while going real slow when first started. Lightly apply brakes and full lock up. Since then I replaced master cylinder, rear shoes and pads. Flushed entire brake system and bled from RABS module first then rear to front. It seemed to fix that but I still have a soft pedal. I just lived to learn with it. No matter how much I bleed it's still soft. And yes the rears are adjusted.
Old 01-15-2015, 04:45 PM
rla2005's Avatar
rla2005
rla2005 is offline
Received 1,172 Likes on 926 Posts
All of my OBS style trucks have exhibited very touchy response when the brakes were cold. One of my Lightnings would lock up both rear wheels with just a few ounces of pressure on the brake pedal. Once the brakes warmed up a bit they operated normally. It's kind of like any Microsoft product..it has "features" you learn to live with.
flyday58
1999 to 2016 Super Duty
11-27-2012 07:36 PM
mismy68cougar
1983 - 2012 Ranger & B-Series
17
01-23-2011 10:25 AM
2 stroke man
15
09-20-2009 05:06 PM
bronco68
03-07-2004 06:31 PM
himilage351
09-08-2001 01:24 AM
Quick Reply: ABS, VSS, Speedo, something's JACKED and Godzilla doesn't like to stop
