No crank problem
Old Jan 8, 2015 | 11:01 PM
Montana300's Avatar
Montana300
No crank problem
Hi all, 1985 F-150 with 300-6, NP435, 4WD. A year ago, I had the engine replaced and the long block was from a fuel injected truck so the shop put in an electric fuel pump. They did it wrong, which required me to replace the fuel pump (but that was another thread). Now, I have a weird problem-sometimes the truck won't crank. Turn the key and it makes a "click" like a bad starter solenoid, but I repalced that already. On top of that, turning on the headlights (without the truck running) causes the fuel pump to get power and start operating! I'm tapped into a yellow striped red wire on the driver's side fender to power the fuel pump (not the fat wire) which is how the shop that installed the motor powered theirs (not that they did ANY part of that job right). I think I must have a short somewhere, but I can't find it. Any ideas?
Old Jan 8, 2015 | 11:09 PM
Tedster9's Avatar
Tedster9
It sounds like a short and it might be, caused by a missing grounding strap. Very common mistake with engine swaps and this would be a possible cause with the info you have. Check that battery negative goes to engine block. Another from engine block to firewall, and engine block to frame. Recheck and grind the mounting surface to bare shiny metal and tighten securely.
Make sure ground return path for fuel pump is OK, it's drawing power through your headlights, this not OK.
Old Jan 9, 2015 | 04:31 AM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
X2
You have an open in the ground path, not a short on the hot side.
BIGRED 7.3L
Sep 28, 2010 09:57 AM
dyoungen
Dec 25, 2009 01:32 PM
JP_McCann
1997 - 2003 F150
Aug 2, 2009 05:02 PM
Dave88F250
Nov 1, 2005 07:34 PM
littleme0382
Sep 16, 2004 06:15 PM
