1988 F-350 with a 460 rattle
I have exhausted every resource I have in diagnosing this 1988 f-350 with a brand new 460 in the vehicle,
I replaced motor and tranny at same time and now have a very metallic type noise coming from upper end area. able to verify noise at a stop, by revving the engine at 1800 rpms and snapping the throttle. When driving the vehicle, there is a rattling type noise coming from engine area under a load. when driving the noise occurs between 1200 and 1800rpms.
By mistake, we got the timing extremely far off and had no power. But the noise went away. Once we got timing back on track, noise was back! compression is within spec, leak down test was completed. Has new distributor. All new ignition components.
Any suggestions? please and thank you
it was a complete drop in from ford. brand new remanufactured motor. we removed valve covers, and inspected valve train, made sure push rods are all the same lengths. and everything looks correct.
was told there is 2 different 460s. one for a truck and one for a car. could a car one do this with truck bolt ons? distributor and so on?
78f250351cleveland
17
03-06-2015 01:27 PM
