4x4 completely out. Could it be simple?
Old Jan 7, 2015 | 07:31 AM
WoundedVet's Avatar
WoundedVet
My 2001 Excursion's 4x4 low and high do not work at all. Any chance it could be a simple issue? I bought the vehicle last spring and didn't notice any issues until it started to snow.
Old Jan 7, 2015 | 07:48 AM
projectSHO89's Avatar
projectSHO89
Yes, it could be simple...or not.
Old Jan 7, 2015 | 07:59 AM
WoundedVet's Avatar
WoundedVet
Great reply
What should I check first? I know the dealership will be licking their chops once I bring it in.
Old Jan 7, 2015 | 08:00 AM
Toreador_Diesel's Avatar
Toreador_Diesel
FTE Leadership Emeritus
When you have a A/C on, does it default to defrost?
If so, you have a vaccum leak at one of the hubs and your lines may need to be replaced.
You should also consider greasing your hubs as this is a commonly neglected maintenance item. Riffraff Diesel sells a fitting that works perfectly and can save you the cost of having to replace hubs.
Front ABS Grease-able Block Off Fitting - Riffraff Diesel Performance
Welcome to guzzle's 4x4 Autolock Hub Lubrication Maintenance Web Page
You may not have to go this far, but just in case: Welcome to guzzle's 4x4 Needle Bearing Maintenance Web Page
Old Jan 7, 2015 | 08:01 AM
Krazee Matt's Avatar
Krazee Matt
Veteran: Navy
Do you get the proper associated dash lights? If not I'd start with troubleshooting the switch, double checking the fuse/relay, etc.
If you're getting the lights functioning properly...
Could also be a vacuum leak, front hubs are ESOF setup and the lines are just standard soft line rubber that'll deteriorate over time.
Greasing up the hubs wouldn't be a bad idea as they tend to get forgotten and neglected. Clay at RR sells a nice adapter for greasing simplicity.
Old Jan 7, 2015 | 08:04 AM
Krazee Matt
Veteran: Navy
Dammit Razzi. Not only is your truck a little faster than mine, apparently your fingers and skills are too. Great minds think alike apparently...
Old Jan 7, 2015 | 08:06 AM
David - WI's Avatar
David - WI
Does it switch to LOW range but not engage the front axle, or does the transfer case not respond at all? (Mine would shift to low range but not engage the front axle... the new vacuum solenoid fixed that in about 2 minutes of work.)
Old Jan 7, 2015 | 08:16 AM
WoundedVet's Avatar
WoundedVet
This sounds very spot on. I'll double check. Probably unrelated, but my heater defaults to defrost sometimes?
Old Jan 7, 2015 | 08:17 AM
WoundedVet's Avatar
WoundedVet
Originally Posted by David - WI
Does is switch to LOW range but not engage the front axle, or does the transfer case not respond at all? (Mine would shift to low range but not engage the front axle... the new vacuum solenoid fixed that in about 2 minutes of work.)
It doesn't appear to change/engage at all, but I'll investigate further.
Old Jan 7, 2015 | 09:27 AM
Lance Helmert's Avatar
Lance Helmert
The heater defaulting to defrost could be a vacuum leak at the hubs when you engage the 4 wheel drive. Have you tried manually locking the hubs? It sounds like you have a vacuum leak for sure. If the transfer case isn't shifting to low range you have another problem. Remember you have to hold the brake for it to shift to low range. Find an icy spot or jack up a rear wheel, put it in gear and have a helper see if the front driveshaft is spinning.
Old Jan 7, 2015 | 10:22 AM
WoundedVet's Avatar
WoundedVet
Thanks. I'll head out and test this right now.
Old Jan 7, 2015 | 10:23 AM
EXv10's Avatar
EXv10
What happens when you turn the dials to the right?
Old Jan 7, 2015 | 04:39 PM
Rscottc's Avatar
Rscottc
Is this a permanent fitting for 4wd or just 2wd?
Remove ABS fitting to use this???
Old Jan 7, 2015 | 05:13 PM
Riffraff Diesel's Avatar
Riffraff Diesel
PREMIUM SPONSOR
Here you go.
Riffraff Diesel Front ABS Grease Fitting.pdf
Old Jan 7, 2015 | 07:38 PM
projectSHO89
Start with checking the relevant fuses.
The vacuum leak is important in that your hubs won't engage via the ESOF controls. If you have the manual locking overides, you can always engage the hubs that way. However, that leak isn't the cause of your particular reported symptom of no activity at all.
