Aerostar Ford Aerostar
Temp Gauge Reading Low?
Old Jan 18, 2015 | 05:39 PM
xlt4wd90's Avatar
xlt4wd90
Originally Posted by iszatso
Followed this thread with interest. Answer comes at the end of thread. Maybe your culprit for the fluctuating gauge..
BRGDS,
patrick
Radiator - Likely? Older van, so scale may be causing blockage. Temps have increased with time. No fluctuation between sitting and highway speeds supports blockage. No issue when outside temps are colder also seem to support blockage theory.
Conclusion: Radiator is okay with winter temps, but reaches it's cooling capacity with summer temps.
I once had a car that would overheat whenever it was put under heavy load, such as going up a long hill. I kind of accidentally found out that the top half of the radiator remained cold even as the temp light came on. It turned out the upper tubes, where most of the cooling would occur, were clogged with hard water residue. I took it to a shop to have it cleaned out for like $50, and it worked great to the day that I sold it. That was an old brass radiator with end tanks that were soldered on. I'm not sure if you can do the same with the Aerostar's aluminum tanks that are glued on.
Jose,
Did you take any actual temp measurements at the radiator? Like with either a contact type thermometer or one of those IR sensors? You can compare these readings to your other vans where the temps read more "normal"
Old Jan 18, 2015 | 06:19 PM
Jose A.'s Avatar
Jose A.
xlt4wd90,
no I haven't, now you're getting me into hot water (no pun intended)
besides, my 1986 and 1992 were sold, I have no way to check them either.
Old Jan 18, 2015 | 10:41 PM
87&97Aerostrar's Avatar
87&97Aerostrar
Last summer on my 97 3.0 the bypass pipe that the temp gauge sensor screws into started leaking. After replacing it, my gauge went from running around the R to running right around the A in normal. Replaced the sensor. No change. Replaced thermostat. No change. Installed complete aftermarket gauge. Read 240 degrees. The highest reading I got with an IR gauge was 210 with ambient temp over 90, A/C on. The van was driven all summer with this reading and no physical indications of overheating.
Duct Tape Racing
Feb 4, 2018 06:22 PM
nolan62
Jan 9, 2014 02:00 PM
Hussler
Sep 27, 2013 05:57 PM
geearturi
Aerostar
Dec 9, 2012 01:30 AM
Lance1601
Aerostar
Mar 15, 2006 11:39 PM
