Ok MY 1993 f-150 xlt 5.0v8 with four speed auto.......i put the truck in park and it goes in reverse lol.....i play around with it....and i get it in park....sometimes with a little roll and grinding type noises......most of the time it is ok tho.....i beleive it is the shift linkage that just is lose....anyone got any other ideas? and also when i put it in gear it isnt "right" over the drive letter.....thanks alot......
Nick
__________________________________________________ _
The best thing happened the other day.......1991 stang 5.0 vs. 1996 camaro z28...........green light turned........guy in camaro broke his ****......took three guys to push it off the track.......and the guy in the stang came back around laughing.........funny stuff
Your steering column with the wheel, clock spring, MFS, and shrouds removed. You should recognize the shift lever on the L side of the pic. You're viewing it from the R side. The light blue pointer is the lock cyliner, where the key goes. The orange ones are where the shift cable connects. There's another pic of it from the other side in the GP Pics album in my signature link.
SteveThanks again for your help..But i need some more........if you had to say, How hard and how much time will it take for someone not automotively inclined to do. And just the basics on how to do it.......Thanks again for your time man.....
Look it up here, but put "f150" in the Model field; not "f-150". You have to pull the headligh ****, cluster bezel, dash panel below the column, 4 screws from the bottom column shroud (it can hang by the tilt lock), and then the top shroud. If that doesn't give you enough room to get to the loose screws, you have to release the tiny shift indicator cable, 4 nuts that hold the column up, and drop the column. It's actually a lot easier that that sounds.
