As your fuel tank gets lower you will find your MPG increasing. A full tank weighs @223 lbs. Doesn't seem like much,, but I see an increase in mileage with a decrease in fuel. Just my .02
did the round trip again to the motherinlaws again.(240mile round trip).First trip ran 75 mph,got 17 mpg.This trip ran 70 mph got 18 mpg. Guess you just gotta slow down!
I drive like an old man ( I am). I got messing around with tires and rims and that had a huge impact on mileage. With the stock tires on 20" rims I was getting 17.5 mpg according to the the trip/fuel display. I took a big hit on mileage when I put the 18" rims with P265/60 tires on it. I now have LT275/65 R18's on the truck that should return me to the original mpg performance. I would get between 20 and 21 mpg on straight highway driving at 60-65 mph. I should get that again with the ne, w tires. I am at sea level to 750' ASL.
I have have had the TCM module adjusted to accommodate tire changes. I have use an accurate hand held GPS unit to check mph, distance and it closely matches the Ford MyTouch display.
If you put oversize or undersize tires and lift kits, it will have a big hit on mpg.
Reason: Update
Well did the 240 mile trip again yesterday.Pretty much no wind about 70 degrees. This time I ran 65 mph and got just under 23 mpg per the dash gauge.Guess if your not in a hurry you can get really good mileage!
Not to mention at that altitude your 5.OL is taking a hit on power.
Yes, at this altitude I'm probably making about 20% less power than sea level...so I think my 17mpg is pretty good for the amount of power I have.
The good thing about altitude is that when I tow my old '67 out to MI for the Woodward Cruise this summer is they will both feel like I just added a blower.
Now that I have the new tires on the truck, I have been showing 13.5 mpg.
That is a +/- 22.5% decrease in mileage compared to the mpg with the original Pirelli Scorpion ATX P275/55 R20 tires. I replaced all four wheels with Goodyear Wrangler AT/S LT275/65 R18 which is what Ford provided as a spare.
Comparing the Wranglers to the Pirellis shows the Wranglers to be slightly larger in circumference (0.52 in) and larger in diameter by 0.16 in and requires fewer revs per mile by 3.26.
The speedometer was recalibrated to the LT275/65 R18 tires. A check with a separate GPS appears the speedometer is fairly accurate.
Logic would dictate that I should be getting pretty close to the original 17.5 mpg overall, but I don't.
The service manager says it is the new tires that is causing the drop in mileage.
My truck has the Goodyear Wranglers. Maybe that's the problem? My last truck(2010 F150) had Goodyears and they only lasted 50k miles.Maybe when I wear these out I,ll try something else.
A couple reasons you will get worse mileage with that tire change:
- The new tires will have a higher rolling resistance than the old ones. Yes, that's a real factor.
- Those new tires a lot heavier than your old ones. This should be a bigger factor around town.
P-metric tires may not make sense for a lot of us, but they do get better mileage then LT tires, I think that's been proven time and again on these forums.
77,
Thanks for pointing out a couple things I overlooked.
1. My current Wranglers weigh 6.1 pounds more per wheel than the original Pirellis.
2. The Wranglers do have a more aggressive tread suitable for off road and mud.
I expected somewhat of a hit on mileage but not 22%.
I guess the above coupled with winter blend gasoline will add up.
I will be taking a road trip to South Texas this week, most of it highway driving but with off road sandy clay two tracks that get slick when wet. I'll see what happens and I'll let you all know.
A friend of mine that I meet down there had a new F150 and complained that the stock Pirelli Scorpions were fine on the road but poor on the two tracks around the ranch.
