Prolonged Starts
I've been having a problem here for a little bit, I think I know what it is but I really could use some advice. My thing is construction I love to build things, mechanicing is more a necessity for me. Anyways here is my problem, when I try to crank my 6L it takes for ever (10-15sec) before she will start. I've done some rooting around and I believe that the oil is draining down back into the pan.
Does anybody have any ideas where I should look? Are there seals in the oil cooler that need to be replaced, how about the stand pipe for the HPOP?
Any comments or advice would be appreciated, also if I do have to go all the way down to the oil cooler again (EGR DELETE last time) are there other things that should be done while I've got the top open?
Thanks,
BigJohn
2006 6.0L F-250 Super Duty Crew Cab
If it ain't broke, use a bigger hammer...
Make sure you have fuel pressure (an add-on gauge is required)
Watch you ICP/IPR values while cranking (requires an ODBII gauge: scangauge2 or smartphone APP + ODBII adaptor)
As you can see, without an ODBII gauge to "see" what's happening it's all sort of a guessing game.
thanks for the insight
BigJohn
My problem started immediately after replacing my ICP sensor. The next morning it took a long crank before starting. Actually, I've never just cranked it once until it started, thinking I might overheat the starter or that it might be a fuel issue. Instead, I cranked about 15 seconds, stopped, recycled cranked again about 15, recycled, and it started on the third crank. Threw out a puff of white smoke that rose up in the air. For the rest of the day, it starts just fine.
It does that every day, but only if I let if get stone cold. I came out at 3am after stopping driving around 10pm and it started right up, and then started just fine again in the morning. But, if I leave it off from 10pm til the morning, I get the long crank syndrome.
What should I be looking for on my ScanGauge? When I started this morning, for the first time I thought to look at my oil pressure gauge while cranking, but I messed up. Cranked it for about 10-15 seconds and the oil gauge didn't move, but right as I let off the key, it jumped to normal, then when I cranked again, it fired right up.
Is there anything about replacing the ICP that could have led to this, or maybe better stated, allowed this problem to surface? Just strange that it started exactly when I made the change. The new sensor fixed the other problems I was having with ScanGauge - no ICP voltage registering (although the truck ran just fine) and the IPR never going below 32 (which I figure was the "implied" reading when no reading was being received, although it seemed to read normal while driving, it just wouldn't go down to 24 at warm idle. Now it does.)
I just came off a 3000 mile road trip through the Appalachians pulling 10k pounds on my trailer and the truck performed just fine. Never really stopped long enough for it to go stone cold, but I got home yesterday and when I came out this morning, it did it again.
Strange, it makes a sound like a gas engine trying to start before taking a while longer to crank and finally starting. Never had it or my diesel tractor do that. They've always either started or not started.
Does that sound like a fuel issue? Actually due for a fuel filter replacement now, but it wasn't when this issue started, and I've recently replaced fuel pump and blue spring.
Wondering if I have an electrical short in that sensor circuit that's making it act funny. Maybe I'll try unplugging the ICP sensor and see what that does.
pulled the values from an old thread..
If you have no sync between CMP/CKP sensors the truck wouldnt Start at all
try these codes
SYC Crankshaft Position Sensor TXD: 07E02209CD RXF: 0462050906CD RXD: 3000 MTH: 000100010000 NAM: SYC
Alternate - if the 1st doesn't work..
SYC Camshaft & Crankshaft in sync (1 = in sync) (AlternTXD: 07E02209CD RXF: 0462050906CD RXD: 3001 MTH: 000100010000 NAM: SYC
Thx
This morning, I just kept cranking it the first time, and after about 25 seconds, it started making that gas engine sound. Prolly would have started if I kept cranking, but I was just trying to check the ICP so I didn't continue.
Also, when it finally does start, a puff of white smoke comes out the exhaust and rises - I thought that was excess fuel from me cycling it three times.
I think you might be right about it draining out. Strange that it takes so long. After 4-5 hours sitting, it still starts right up. What would make it drain like that?
Thinking...I do have one injector that I haven't replaced. Wonder if it's leaking fuel? I need to change my oil, so maybe I start it up, then shut it down and drain all the oil out and leave the plug out and see if fuel drains out of the pan overnight.
Still strange that it didn't start doing this until I replaced that sensor.
