The blower motor resistor PCB is shot. "High" is the default when the boards blown. Not sure where its located on a 99 but likely around the blower motor. Purchase the part then look for it under the dash. <$20 part.
Connector looked OK, I picked up a resistor at Autozone for $15, now I need to find the time to put it on. Its located under the hood attached to the blower, shouldn't be that hard.
Thanks Guys!!!!
Tried to install it in freezing cold weather yesterday, but was unable to bet a good hold of the bottom screw. Once I replace it and confirm it's fixed, then I'll close the loop.
Thanks for looking?
