54 to 56 dash conversion
Old Jan 4, 2015 | 01:33 AM
jboy32's Avatar
jboy32
Hey yall, ive always liked 56 dash/gauge clusters better than 53-55. My question is has anyone done a conversion before? Ive read that the dash is semi-structural so it can not simply be swapped...any truth to this? Im sure with time, money, and know how anything can be done but im looking for a more or less straight forward swap. Anyone with info, links, pics, etc the help would be great.
thanks yall
Jon
Old Jan 4, 2015 | 08:21 AM
bjmayberry2's Avatar
bjmayberry2
Veteran: National Guard
As you said with time money etc anything can be done. I would think the first thing to be adressed iare the ends. The 56 has ends that allow for the "wrap around" windshield.
1956 Dash Assembly
Old Jan 4, 2015 | 09:26 AM
gas6999's Avatar
gas6999
dash
Its all how bad you want to change it, it can be done but its not a bolt in dash, I put a 51 Victoria dash in my 54 looks great, but my dash was cut to pieces so I had to do something with it, I welded a 1 1/2" tube from side to side for strength then welded in the dash, tapered to the original door opening, looks like it came in the truck, it wasn't a bad job, just a little cutting and welding. good luck George.
Old Jan 4, 2015 | 11:55 AM
pweng1's Avatar
pweng1
We would love to see pics of that.
Old Jan 4, 2015 | 03:58 PM
jboy32's Avatar
jboy32
Im thinking the easiest way to make this happen would be by aquiring a 56 dash and cutting out the cluster section, then removing the 54 section and welding in the 56.
My worry is ive noticed that 56s seem to have more of a roll/bend on the transition from top to bottom. But then again that could be fixed with a little metal or fiberglass work. Just trying to think/research in advance. Thanks guys
Old Jan 4, 2015 | 06:09 PM
abe's Avatar
abe
I think the easiest way to get a 56 dash is to buy a 56 truck! LOL
GM4WALLS
Jan 1, 2016 01:51 PM
PRO49FORD
Aug 14, 2015 02:22 PM
scottjo
Sep 14, 2007 01:22 PM
gusso
21
Dec 24, 2006 05:57 PM
julie 54
Paint & Bodywork
Mar 20, 2002 10:40 PM
