My 2014 CC with about 10k on the clock has a vibration that starts as soon as I put it in gear. It used to be intermittent but now is most of the time. I'll end up taking it in but was wondering if anyone has ever run in to this. With it vibrating when stopped but in gear leads me to think it's something in the transmission.
My 2014 F-350 does the same thing. When you find out what it is, let me know what it is.
Are you saying it does it at a complete stop? Or when you first start moving in 1st gear. If doing it while stoped it may be a miss in the motor,bad plug?
It doesn't feel like a miss, just a vibration when stopped at a light while in gear. Plus, with a miss, it would throw a code(s). It could be a bad exhaust hanger which is allowing the exhaust to transmit vibrations through the body. Unfortunately only dealership that I half-way trust is 300 miles away in another state so I just can't have them test drive my truck.
Started noticing the same on mine while in gear at a stop. No other symptoms and truck runs strong. Actually was thinking of removing my 5 star tune to see if that was causing it. You guys running a tune? Just hit 13k miles on mine.
My truck is OEM stock with 14K on it. I can even feel my vibration through the steering wheel.
I was reading some reviews off site.One of the vehicle magazines and i saw it somwewhere else that for 2015 super duty got a new torque converter.Do not know why though
