buying a used engine
Old Jan 3, 2015 | 12:09 PM
Tlid1011's Avatar
Tlid1011
hello i have a change to buy a used 6.0 engine which i need it has 104k miles on it however it needs a hpop icp and ipr sensor and also a turbo the guy said his lowest price is 2500 i was wondering if that is a good price or not
Old Jan 3, 2015 | 12:27 PM
Jmoen7's Avatar
Jmoen7
Sounds like it's going to need a full tear down when you get it, will be cost effective to do the work yourself. If you want it all finished, get that thing rebuilt, turbo reconditioned and plant it in your truck for some trouble free miles.
It wouldn't hurt to know how long he abused it for to have killed all those parts without replacing one
Old Jan 3, 2015 | 12:52 PM
Grant-Dieseltech's Avatar
Grant-Dieseltech
If he didn't just sell them off of it.
2500 isn't bad, but what's wrong with yours?
Old Jan 3, 2015 | 01:16 PM
Jmoen7's Avatar
Jmoen7
well, those 4 things are fed off oil. Could have snowballed in an oil system issue
Old Jan 3, 2015 | 01:45 PM
Tlid1011's Avatar
Tlid1011
he sold the turbo but the others are bad my rods are bent hydrolocked at 80 mph wont crank manually disconecting the cable on top of the engine on passenger side and touching it to the battery
Old Jan 3, 2015 | 01:53 PM
Shaneb75's Avatar
Shaneb75
Strokin Okie
Have you tried cranking it over by hand?
Old Jan 4, 2015 | 02:54 AM
Poor'it in'her's Avatar
Poor'it in'her
Yeah I would try and get the engine turning over by hand but if you can't, before I spent any money on another engine I would pull the valve cover and remove each rocker arm assembly and check the rods while you're in there. Each time you remove a rocker arm assembly and inspect the rod, try to rotate the engine one full turn. Make sure that the truck is not energized removed the cables from both batteries. Just remember there's a procedure for replacing the rods and rocker arm assemblies back together!
Old Jan 4, 2015 | 09:11 AM
78fordman's Avatar
78fordman
I think he is meaning his connecting rods are bent, not the pushrods.
Old Jan 4, 2015 | 10:53 AM
Poor'it in'her
!!! Oh !!! Oh no!!
Old Jan 4, 2015 | 10:57 PM
Jeff Watts's Avatar
Jeff Watts
I'm in a similar situation. Bad engine. Looking on ebay, there are tons of remans out there, but then I'd be forever worried about what kind of cheap chi-com parts they loaded it up with. I'm going to buy a used running engine, and then go through it myself.
Old Jan 5, 2015 | 12:47 PM
mhatlen's Avatar
mhatlen
2006 Bullet-Riddled 6.0
Used 2005 engine
My brother in law has one still in the truck but it's here in California.
I'm sure price is negotiable.
Was running but he stripped the truck for body parts.
Old Jan 5, 2015 | 01:32 PM
Jeff Watts's Avatar
Jeff Watts
I'm second in line in this thread, and it's going to be a couple paychecks for me, but if there's no other takers, I'm interested, if he's willing to put it on a pallet and ship it.
Old Jan 5, 2015 | 01:53 PM
mhatlen's Avatar
mhatlen
I can give his info if you guys are interested. I would imagine that's not cheap to ship.
They are over 1,000 lbs.
Old Jan 5, 2015 | 03:02 PM
Jeff Watts's Avatar
Jeff Watts
Forward Air works shipping miracles. You have to drop it off at their dock, and pick it up at their dock, but you can't beat their rates.
JHoffman93
Sep 17, 2011 06:44 PM
Scorpolis
Sep 2, 2011 01:28 PM
ackeiyword
General Diesel Discussion
Dec 13, 2010 11:42 AM
Flux
Aug 7, 2006 08:28 PM
JMorton
24
Jun 23, 2004 06:57 PM
